[OpenLayers-Users] Handling double click
Eric Lemoine eric.c2c at gmail.com
Mon May 19 12:54:12 EDT 2008
Hi. I'm not sure i understand. Do you use OL click handler or have you
implemented your own double click handler? OL click handler supports
double click. So use that handler with appropriate options, in part
use stopClick:true and make sure you activate the handler after the OL
controls. Tell me how it goes. Eric
2008/5/19, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
> I have a map where several features have links attached.
> A script checks the current cursor position against the server to
> determine if there is a link at the current location.
> If there is, the cursor changes to the hand cursor.
> This all works fine.
> Regardless of what tool the user has, I would like to intercept a
> double-click.
> I can do that with the doubleclick handler:
> doubleClick = new OpenLayers.Handler.DoubleClick(this, {dblclick:
> this.OnDoubleClick}, {single: false, 'double': true, stopSingle: false,
> stopDouble: true});
> doubleClick.activate();
> And it works, but the original tool also gets activated.
> Ea., if the zoom tool is activated, it zooms twice for a double click,
> as well as activating the custom doubleclick handler.
> Is there any way to achieve this?
> It seems that the "click" event is fired before the "doubleclick" event
> happens, so it is difficult to filter the click.
> My handler looks like this:
>     OnDoubleClick: function(evt)
>         if (this.activeLink != null)
>             window.open(this.activeLink, this.target);
>             OpenLayers.Event.stop(evt);
>             return false;
>         else
>             return true;
> The "return false" does not prevent the click events from occuring.
> Stopping the single click events makes the current tool useless.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
