[OpenLayers-Users] OpenLayers.Layers.Text with variable filename as input
Carl Morgan carl.r.morgan at noaa.gov
Mon May 19 14:26:29 EDT 2008
Ok, I have it working. Looks like my problem was simply with bad
javascript syntax.
Carl Morgan wrote:
> Hello,
> I am very new to OpenLayers and just as new to javascript, so I
> apologize in advance for my lack of basic understanding of all of this.
> But, I am attempting to plot points on a map using
> OpenLayers.Layers.Text and it works just fine. However I would ideally
> like to pass the filename in through the URL. In the following line, I
> would like to replace "./lsrtext.txt" with a variable but am having no
> luck.
> var newl = new OpenLayers.Layer.Text( "text", {location: "./lsrtext.txt"} );
> Is it possible to do such a thing? I have the code working which
> processes the variable name, and I am able to process the lat, lon and
> zoom level this way. But I can't seem to get it working with the
> filename. The documentation states that the URL of the text file can't
> be changed once passed in. Does this count as changing?
> Thanks for any help!
> -Carl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
