[OpenLayers-Users] overviewmap style properties
Alessio Di Lorenzo alessio.dilorenzo at gmail.com
Mon May 19 17:50:34 EDT 2008
OK Tim,
I will try as soon as this method.
Thanks a lot for your detailed explanation :-)
alessio
Tim Schaub ha scritto:
> Ok, a few things.
> If you do not include a link to the default stylesheet in a page that
> creates an OpenLayers map, then OpenLayers magically appends this
> stylesheet to the page for you.  This bit of magic will bite you if
> you try to customize styles - since your declarations will likely be
> evaluated before the default css loads.
> So, step one, add the following to your page head:
> <link rel="stylesheet" href="path/to/default/style.css"
> type="text/css" />
> Then, below this, add any custom style:
> <style>
>     .olControlOverviewMapElement {
>         background-color: #FF0000;
> </style>
> I just did this for the Overview Map example
> (http://openlayers.org/dev/examples/overviewmap.html), and I see, as
> expected, a red background for my overview map.
> If you do not see this in IE, please try the following:
> In your map options, explicitly set the theme property to null - this
> stops the magic bit from happening where it shouldn't be happening in
> the first place.
> var map = new OpenLayers.Map("map_id", {theme: null});
> If this works in IE but the previous step did not (adding a link to
> the default stylesheet and customizing style below), then open a
> ticket with this as a bug and write back.
> For elements that are styled with css, you should *not* have to use
> !important declarations.  This declaration means ignore any previous
> and subsequent declarations and use this one.  In the above
> description, the default css is loaded first and your custom
> declarations follow - so !important is not necessary.
> The !important declaration is useful where style is declared in the
> code.  This exists in many places in the library - it is an
> acknowledged problem waiting for a champion.  The overview map is
> already styled with css.
> Again, if you properly link the default style and add your custom
> style after and this still doesn't work in IE, open a ticket and write
> back.
> Tim
> Alessio Di Lorenzo wrote:
>> Yes... I solved right now with a google search... using !important as
>> you says
>> I'm quite new to these "css tricks"... :-) (and I hate IE, again)
>> thx to all, alessio
>> Lance Dyas ha scritto:
>>> Did you try using the css
>>> padding 0px important!;
>>> background:none important!;
>>>> I'm doing some experiments.
>>>> Defining the .olControlOverviewMapExtentRectangle class in my css
>>>> it works well, applying the new style both in FF and IE.
>>>> It seems like my .olControlOverviewMapElement class can't overwrite
>>>> the correspondent class in the default style.css if using IE (I
>>>> hate IE...)
>>>> Alessio Di Lorenzo ha scritto:
>>>>> Hi and thanks for your answer Christian.
>>>>> Your suggestion works well in Firefox :-)
>>>>> ...but not with IE.
>>>>> I added this css definition to my custom stylesheet:
>>>>> .olControlOverviewMapElement{
>>>>>        -moz-border-radius-bottomleft: 0pt;
>>>>>        -moz-border-radius-bottomright: 0pt;
>>>>>        -moz-border-radius-topright: 0pt;
>>>>>        -moz-border-radius-topleft: 0em;
>>>>>        background:none;
>>>>>        padding: 0px;           }
>>>>> on IE6 and IE7 the blue background and the padding values remains
>>>>> active.
>>>>> maybe you understand what's wrong?
>>>>> alessio
>>>>> Christian López Espínola ha scritto:
>>>>>> Just create a new css and link it in your page, or put a style
>>>>>> section
>>>>>> in your page's head after the inclusion of the OL css..
>>>>>> There you override the styles that you want to change.
>>>>>> HTH
>>>>>> On Sun, May 18, 2008 at 6:10 PM, Alessio Di Lorenzo
>>>>>> <alessio.dilorenzo at gmail.com> wrote:
>>>>>>> Hi list,
>>>>>>> I'm working on the overview map outside the map viewport and
>>>>>>> everything
>>>>>>> is going fine but I don't uderstand if it is possible to restyle
>>>>>>> the
>>>>>>> overview map (by deleting, for example, the blue border) without
>>>>>>> working
>>>>>>> directly on the style.css file.
>>>>>>> I read the online docs concerning the minRectDisplayClass
>>>>>>> http://dev.openlayers.org/releases/OpenLayers-2.6/doc/apidocs/files/OpenLayers/Control/OverviewMap-js.html#OpenLayers.Control.OverviewMap.OpenLayers.Control.OverviewMap
>>>>>>> but I don't understand exactly how to use it and if this class is
>>>>>>> suitable to reach my purpouse... that is to manage the overview
>>>>>>> map style.
>>>>>>> Could you give me some hints?
>>>>>>> thx in advance, alessio
>>>>>>> _______________________________________________
>>>>>>> Users mailing list
>>>>>>> Users at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>> Users mailing list
>> !DSPAM:4033,48318292209727082231907!
