[OpenLayers-Users] migrate from 2.4 to 2.6 and select
Wendell Turner
wendell at enflight.com
Fri May 23 17:44:51 EDT 2008
The javascript that gdal2tiles.py generates references
www.openlayers.org/api/2.4/OpenLayers.js, however, that
doesn't appear to have SelectFeature. Was SelectFeature
added after 2.4?
If I change the 2.4 to 2.6 it produces this error:
Error: this.projection.getUnits is not a function
Source File: http://www.openlayers.org/api/2.6/OpenLayers.js Line: 772
If I change it to reference my own copy from the
distribution it gets this error:
Source File: http://delta.rho.net/open/lib/OpenLayers/Layer.js Line: 489
What do I need to do to upgrade from 2.4 to 2.6 (so I can
use SelectFeature)?
Thanks,
Wendell
