[OpenLayers-Users] Help dealing with popup clicks verse click
handlers
Kusum
kusum at infobase.in
Tue May 27 00:17:13 EDT 2008
why don't u use hover event to see popup on marker instead of using click.
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
Sent: Tuesday, May 27, 2008 6:28 AM
To: "Christopher Schmidt" <crschmidt at metacarta.com>
Cc: "openlayers user list" <users at openlayers.org>
Subject: Re: [OpenLayers-Users] Help dealing with popup clicks verse click
handlers
> Christopher Schmidt wrote:
>> On Mon, May 26, 2008 at 07:11:24PM -0500, Stephen Woodbridge wrote:
>>> Hi all,
>>> I have a marker layer that which is working great. I just added a click
>>> handler that reverse geocodes on a click and adds a marker at the click
>>> point and populates the popup with the XML response. This is all
>>> working great EXCEPT that when I click on the icons to open or close a
>>> popup, that click is propagating to the click handler causing another
>>> marker to be added.
>>> How to I control or stop this?
>> Return false or OpenLayers.Event.stop(evt); inside your marker click
>> handler. (I can't remember which it is; one of them should do it, I
>> don't know which.)
>> Regards,
> Thanks,
> I was already calling OpenLayers.Event.stop(evt); and added return false
> for good measure, but without success.
> I just found another symptom that might be relevant, which is that this
> behavior only happens UNTIL I do a click drag on the map, then it
> behaves as expected. Opening a popup that causes a pan does not fix the
> problem.
> Sorry I meant to post the url in the last message:
> http://imaptools.com/maps2/tiger.html
> To reproduce:
> enter an address like: 11 radcliffe rd, n chelmsford, ma 01863
> click Go
> Click on the Red Marker you will get an aqua marker where you click,
> click on the close button and you will get another aqua marker.
> Now, reload the page and repeat, BUT after you click Go, do a click drag
> first and then will not get the extra markers.
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
