[OpenLayers-Users] Z-Index of Markers Layer
bradleyspencer
brad at cubewerx.com.au
Thu May 29 06:02:26 EDT 2008
Eric,
Thanks for that. I tried your suggestion.
So this will make the markerLayer a Z-Index one less than the Popup. Right?
However, what I am doing is preassigning groups of layers to z-index levels so they layer predictably and not just as they get dynamically loaded. On top of all this I want to display two markers layers - I have been able to make sure that the two markers layers are above these layers by assigning numbers appropriately.
When I use this suggestion it pushes the markers below the other layers which I do not want to do. Is there any way of making the Popup to be +1 above the markers layers?
Cheers,
Brad Spencer
-----Original Message-----
Sent: Thursday, 29 May 2008 4:30 PM
To: brad at cubewerx.com.au
Cc: openlayers users
Subject: Re: [OpenLayers-Users] Z-Index of Markers Layer
On Thu, May 29, 2008 at 2:52 AM, bradleyspencer <brad at cubewerx.com.au> wrote:
> Well, I fixed one problem. I was not using the map.setLayerZIndex on the
> appropriate markers layer.
> However, now my FramedCloud is now lower than the markers and the overlayed
> layer. Is there anyway to control the zIndex of the FramedCloud?
Hi Brad,
Try this: markerLayer.setZIndex(map.Z_INDEX_BASE['Popup'] - 1);
Eric
