[OpenLayers-Users] Problem with polar projection on Antartica
Eric Lemoine eric.c2c at gmail.com
Thu May 29 11:53:57 EDT 2008
You dont need the projection property in the WMS layer param, do you?
Cheers. Eric
2008/5/29, springrider <springrider at hotmail.com>:
> Thanks Eric for your reply
> I have fixed my problem and this is the code:
> 		var map, layer;
> 		map =new OpenLayers.Map("map", {maxExtent: new
> OpenLayers.Bounds(-8000000,-8000000,8000000,8000000), maxResolution: 25000,
> units:'meters', projection:"EPSG:3031"});
> 		layer = new OpenLayers.Layer.WMS( "test",
> 			"http://localhost:8080/geoserver/wms?version=1.1.1",
> 			{layers: 'fifao:FAO_AREAS_PROJ,fifao:continents_pg',projection:
> "EPSG:3031"});
> 		map.addLayer(layer);
> 		map.zoomToMaxExtent();
> The point is that it works only when the layer corresponds to shapefile in
> my Geoserver and not to a table in my Oracle database. In that case, i
> obtain a white map.
> I don't know if it is a GeoServer or an Oracle problem. If anyone has a any
> idea, keep me informed.
> Anyway, thanks for your help.
> Sylvain
> Eric Lemoine-3 wrote:
>> On Tue, May 27, 2008 at 11:29 AM, springrider <springrider at hotmail.com>
>> wrote:
>>> Thanks Jon for your reply
>>> Sorry I was not really explicit about the result i had.
>>> This is the request which is sent to my Geoserver:
>>> GET /geoserver/wms?service=wms&LAYERS=fifao:CONTINEENT_GAUL
>>> &SRS=EPSG:3031&VERSION=1.1.1&REQUEST=GetMap&STYLES=
>>> &EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg
>>> &BBOX=-12399999.999999989,8762666.666666664,8762666.66666668,29925333.333333332
>>> &WIDTH=256&HEIGHT=256
>> Do you think the rounding errors are the cause of your problem?
>>> So the SRS to be used is correct (3031) but what is sent for the bounding
>>> box seems to be wrong in respect to what i have specified...
>>> As you were suggesting in one of your previous post, could it be related
>>> to
>>> ZoomToMaxExtent?
>>> I tried to add the projection also for the baselayer but with no results:
>>>        var basemap = new OpenLayers.Layer.WMS( "test",
>>> "http://193.43.36.238:8484/geoserver/wms?version=1.1.1",
>>>                                {layers: 'fifao:CONTINEENT_GAUL',
>>>                                 srs: 'EPSG:3031'});
>>>        basemap.addOptions({isBaseLayer: true});
>> You have only one base layer so no need to set things at the layer
>> level, map level is fine.
>> Eric
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> http://www.nabble.com/Problem-with-polar-projection-on-Antartica-tp17475860p17537271.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
