[OpenLayers-Users] User inputs in Popups
Indika Tantrigoda
indika85 at gmail.com
Sat Nov 1 07:40:03 EDT 2008
Thanks for the link. This is the kinda thing that I was looking for.
2008/10/31 Arnd Wippermann <arnd.wippermann at web.de>
> it's possible to use popups for editing feature attributes.
> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/styles_unique_with_group.html
> If your transcation takes place after you have updated the attributes, i
> would think the transaction should work.
> Arnd Wippermann
> *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *Im Auftrag von *Indika Tantrigoda
> *Gesendet:* Freitag, 31. Oktober 2008 14:22
> *An:* Alexandre Dube
> *Cc:* OpenLayers users mailing list
> *Betreff:* Re: [OpenLayers-Users] User inputs in Popups
> Hi Alexandre,
> Thanks for the reply. I am referring to the html text box inside the popup.
> Thats where I want to enter the data.
> I also included a button in the popup to initiate the transaction. This
> works fine when I hard code the attribute information.
> I did try the method you suggested. Maybe because the html text box is not
> directly in the web page(but rather in the popup) I didnt have much success.
> However I will try this again. Maybe I missed something.
> If there is any other way of achieving this (maybe with ajax) kindly let me
> know.
> Regards,
> Indika
> 2008/10/31 Alexandre Dube <adube at mapgears.com>
>> Hi Indika,
>> >> The problem is I am unable to access the input data.
>> Do you mean you can't access the html text box ? If you do, give it and
>> id, access it with document.getElementById('yourId') and parse the text box
>> value to the feature.attributes before saving. That will add the attribute
>> to your INSERT/UPDATE request at the same time. I'm not sure if that's what
>> you meant, though.
>> >>Also everytime the wfs-insert takes place i get an alert with the
>> transaction results details.
>> Is there anyway not have the alert come up everytime.
>> Search in your files for the "alert" string and just get rid of it.
>> Hope this helps,
>> Alexandre
>> Indika Tantrigoda wrote:
>>> Hello to all,
>>> I have a wfs layer setup which allows me to add points.
>>> I would like the user to enter the attribute information so that it too
>>> can get
>>> written to postgres.
>>> I setup a popup with a text box which allows me to add the relevant
>>> details.
>>> Is there any way to get around this, or this is an alternative method I
>>> could approach.
>>> Thanks
>>> Indika
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081101/63d411ea/attachment.html
