[OpenLayers-Users] Mouseover should show attributes from a
database
Jerome Freyre
jerome.freyre at hispeed.ch
Mon Nov 3 06:04:51 EST 2008
I don't know how you add the features on the map but in my case, i add my
features with a geojson.
This geojson contains properties with properties that contains my DB object
id:
{"type": "FeatureCollection", "features": [{"type": "Feature","id": "60347",
"properties": { "myObjectID" : "123"},"geometry": {"type":
"Point","coordinates": [-4.0281, 5.3411]} }]}
When my mouse is over the feature, I get the id like that :
var id = feature.attributes['myObjectID']
then i made an ajax request (in my case with jquery) that give me db
informations of the object.
var html = $.ajax({
async:false,
//sur la page
url: "../include/getObjectInfos.php?id="+id,
}).responseText;
Finally, I add a popup that contains the ajax response.
// create popup located in the bottom right of the map
var bounds = this.layer.map.getExtent();
// creation of the popup
var popup = new OpenLayers.Popup.FramedCloud("chicken",ll, size, html,
null, true, onPopupClose);
map.addPopup(popup);
Hope it will be helpfull...
Sincerly,
Jérome
View this message in context: http://www.nabble.com/Mouseover-should-show-attributes-from-a-database-tp20299453p20300784.html
