[OpenLayers-Users] OpenLayers+ExtJS 2.2
bartvde at osgis.nl bartvde at osgis.nl
Mon Nov 3 10:27:31 EST 2008
Do you have an example showing the problem?
Best regards,
Bart
> I experienced similiar problems whenuisng jquery !
> Dipl. Inf. Carsten Eider schrieb:
>> Hi folks,
>> as mentioned in
>> http://workshops.opengeo.org/openlayers/intro/doc/integration.html#exploring-ext-js
>> there is a possibility to setup up an application
>> where openlayers and ExtJS 2.2 work together.
>> While searching this list I found a link to
>> http://pearl.ecotrust.org/~twelch/apps/odfw/app.html, showing a
>> working example.
>> my problem is:
>>     * while loading my page the error "evt.layer.events has no
>>       properties/evt.layer.events.register('loadstart', this,
>>       this.increaseCounter);" in LoadingPanel.js(50) occurs
>>     * when removing Loadingpanel_Control the error "layer.div has no
>>       properties/layer.div.className = "olLayerDiv";" Map.js(816)
>> occurs
>> and my map doesn't work any more
>> Any suggestions?
>> Mit freundlichen Grüßen / Yours faithfully
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Kompetenzzentrum für Innovative Informationssysteme
>> c/o Fachhochschhule Bingen / University of applied sciences Bingen
>> Berlinstraße 109
>> 55411 Bingen
>> Tel: +49 (0) 6721 / 409-179
>> Fax: +49 (0) 6721 / 409-158
>> email: eider at fh-bingen.de
>> Internet: iis.fh-bingen.de
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Carsten Eider
> Dipl. Inf. (FH)
> Berlinstraße 109
> 55411 Bingen
> Users mailing list
