[OpenLayers-Users] Mouseover should show attributes from a
 database
    Jerome Freyre
    jerome.freyre at hispeed.ch
    Mon Nov  3 12:14:45 EST 2008
Of course it is easier,
But it depends on the numbers of informations you have to load and the
number of features your are loading.
In my case, there is a lot of informations to load for a lot of points...
So I prefer to load only the id and then load only the information that are
really useful for the users of my application.
Sincerly,
Jérome
Eric Lemoine-3 wrote:
> Jerome, you could also have the GeoJSON include all the information
> you need, thereby avoiding an extra client/server roundtrip, couldn't
> you? Eric
> 2008/11/3, Jerome Freyre <jerome.freyre at hispeed.ch>:
>> Hi,
>> I don't know how you add the features on the map but in my case, i add my
>> features with a geojson.
>> This geojson contains properties  with properties that contains my DB
>> object
>> id:
>> {"type": "FeatureCollection", "features": [{"type": "Feature","id":
>> "60347",
>> "properties": {  "myObjectID" : "123"},"geometry": {"type":
>> "Point","coordinates": [-4.0281, 5.3411]} }]}
>> When my mouse is over the feature, I get the id like that :
>> var id = feature.attributes['myObjectID']
>> then i made an ajax request (in my case with jquery) that give me db
>> informations of the object.
>> 	var html = $.ajax({
>> 		async:false,
>> 		//sur la page
>> 	   	url: "../include/getObjectInfos.php?id="+id,
>> 	}).responseText;
>> Finally, I add a popup that contains the ajax response.
>>     // create popup located in the bottom right of the map
>>     var bounds = this.layer.map.getExtent();
>> 	// creation of the popup
>> 	var popup = new OpenLayers.Popup.FramedCloud("chicken",ll, size,  html,
>> null, true,  onPopupClose);
>>     map.addPopup(popup);
>> Hope it will be helpfull...
>> Sincerly,
>> Jérome
>> View this message in context:
>> http://www.nabble.com/Mouseover-should-show-attributes-from-a-database-tp20299453p20300784.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Mouseover-should-show-attributes-from-a-database-tp20299453p20306669.html
