[OpenLayers-Users] OpenLayers.Request problem;
where is the data?
Tim Schaub
tschaub at opengeo.org
Mon Nov 3 16:29:58 EST 2008
Hey-
Lehtonen, Mika wrote:
> Hi again,
> using $_REQUEST (with your snippet), I get this. What's that?
> array(2) {
> ["__utma"]=>
> string(54) "81555458.1737773788.1225666548.1225666548.1225666548.1"
> ["__utmz"]=>
> string(69)
> "81555458.1225666548.1.1.utmccn=(direct)|utmcsr=(direct)|utmcmd=(none)"
Those are cookie values.
We (or I at least) can only help you out if you post code (preferably
legible).
Thanks,
Tim
> - mika -
> Lehtonen, Mika kirjoitti:
>> Hi Tim,
>> tested that. I get this: array(0) { }
>> I am trying to create a SLD on server side for Geoserver, based on
>> what has been selected on client side. So I have quite a huge number
>> (couple of thousands) of polygon regions of which an end user can
>> choose from (with a "tool"). Chosen polygons should be presented with
>> different style. So I decided to do that using wms. Unfortunately, if
>> I create my SLD on client side and send it server by using GET, the
>> request is way too long.
>> Basically, an array of certain selected polygon attributes POSTED to
>> server, would be enough.
>> - mika -
>> Tim Schaub kirjoitti:
>>> Hey-
>>> Can you write (preferably not all on one line) what you are doing
>>> again to make the request? If you are setting the content type,
>>> include that. Also, note that you can use the POST function and
>>> that you don't need the new keyword. In addition, note that params
>>> are about GET and data is about POST.
>>> I just set up PHP here and confirmed that the following works:
>>> var req = OpenLayers.Request.POST({
>>> url: "my.php",
>>> data: OpenLayers.Util.getParameterString({foo: "bar"}),
>>> headers: {
>>> "Content-Type": "application/x-www-form-urlencoded"
>>> The content of my.php:
>>> <?php var_dump($_POST); ?>
>>> What I see in the response:
>>> array(1) {
>>> ["foo"]=>
>>> string(3) "bar"
>>> The same answer is given here:
>>> http://openlayers.org/pipermail/users/2008-October/008483.html
>>> I've put this example up on the Request wiki page:
>>> http://trac.openlayers.org/wiki/Request#Ex.7:IssueaPOSTrequestwithform-encodeddata.
>>> And, this is now a FAQ:
>>> http://faq.openlayers.org/ajax/how-do-i-post-form-encoded-data/
>>> Good luck,
>>> Tim
>>>> Actually I already tested that. Also setting the Content-length and
>>>> the Connection Close. I haven't been testing this with other
>>>> browsers than FireFox. It seems that the POST method isn't
>>>> responding in any way. Parameters attached to the request however
>>>> seem to be working just fine.
>>>> There was another issue, which might be the same you pointed to me,
>>>> but the symtons are closer to mine:
>>>> http://n2.nabble.com/OpenLayers.Request.POST-GET-errors-td1304742.html
>>>> - mika -
>>>> Arnd Wippermann kirjoitti:
>>>>> Perhaps this solves the problem
>>>>> headers: {
>>>>> "Content-Type": "application/x-www-form-urlencoded"}
>>>>> http://n2.nabble.com/OpenLayers.Request-POST-and-IE-6-7-issues-tt1384863.htm
>>>>> l#a1395114
>>>>> Arnd Wippermann
>>>>> -----Ursprüngliche Nachricht-----
>>>>> Von: users-bounces at openlayers.org
>>>>> [mailto:users-bounces at openlayers.org] Im
>>>>> Auftrag von Lehtonen, Mika
>>>>> Gesendet: Montag, 3. November 2008 10:01
>>>>> An: OpenLayers
>>>>> Betreff: [OpenLayers-Users] OpenLayers.Request problem; where is
>>>>> the data?
>>>>> Hi,
>>>>> I am trying to send a POST request from OL with the following snippet:
>>>>> new OpenLayers.Request.issue({method: 'POST', url:'sld.php',
>>>>> params:{abc:'def', cba:'fed'}, data:{ghi: 'jkl', ihg: 'lkj'},
>>>>> success: function(){alert('Succeeded!');}, failure:
>>>>> function(){alert('Did not succeed.');}, callback:
>>>>> function(){alert('Calling back');}});
>>>>> $_POST array in sld.php stays empty. In $_GET array I can find the
>>>>> params: def and fed. How can I get touch with the data? Am I doing
>>>>> something
>>>>> wrong here?
>>>>> - mika -
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>> Users mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
