[OpenLayers-Users] yet another spherical mercator / geographic
question
Christopher Schmidt
crschmidt at metacarta.com
Wed Nov 5 09:27:48 EST 2008
On Tue, Nov 04, 2008 at 04:36:27PM -0800, Andrew Schuh wrote:
> I have managed to get all of my data in EPSG900913 believing that would help
> me overlay on google imagery but I still have a nagging problem. I have a
> vector data source representing some polygons. These display very
> accurately against google imagery at very high zoom levels, several hundred
> meters across in window. As one zooms out, it becomes just slightly offset
> to the south, several hundred miles in window. Not terrible, but definitely
> noticeable to a user, especially when the polygons are sandwiched up against
> a river bank. The basics of the code are below. Is this an error in my
> coding or a limit of what one can do w/ overlaying on the spherical mercator
> imagery?
I don't see an obvious error in your code, nor is this a problem I've
ever run into. Cna you provide an example that reproduces this publicly?
If not, ca you publish a full HTML page and a copy of data you can
reproduce the problem with?
-- Chris
> function initmap(){
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:900913"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508.34,-20037508.34,
> 20037508.34, 20037508.34),
> numZoomLevels:22
> map = new OpenLayers.Map('map', options);
> var gsat = new OpenLayers.Layer.Google(
> "Google Satellite",
> {type: G_SATELLITE_MAP,
> sphericalMercator: true }
> OpenLayers.loadURL("/rcbra/web/content/maps/DecisionUnits.geojson",
> null,
> this,
> onGeoJsonLoadSuccess,
> onGeoJsonLoadFailure
> function onGeoJsonLoadSuccess(data) {
> var geojson_format = new OpenLayers.Format.GeoJSON();
> var pizzastores = new OpenLayers.Layer.Vector("GeoJSON Layer");
> map.addLayer(pizzastores);
> //alert(data.responseText);
> pizzastores.addFeatures(geojson_format.read(data.responseText));
> function onGeoJsonLoadFailure(data) {
> map.addLayers([gsat,terraservice]);
> map.addControl(new OpenLayers.Control.ZoomBox());
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition());
> map.addControl(new OpenLayers.Control.Permalink());
> View this message in context: http://www.nabble.com/yet-another-spherical-mercator---geographic-question-tp20334402p20334402.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
