[OpenLayers-Users] ModifyFeature: Rotate Center Point and
Control Point
carls
carlshe at 163.com
Thu Nov 6 09:04:20 EST 2008
I just try to do some modification to ModifyFeature.js and Geometry.js.
one function 'GetCenter()' is added to OpenLayers.Geometry, and a little
modification is applied to 'collectDragHandle' and 'collectRadiusHandle' of
ModifyFeature.js.
for Geometry.js:
GetCenter: function() {
var vertices = new Array();
var center = new OpenLayers.Geometry.Point(0, 0);
var xx = 0, yy = 0;
* Method: Collect All Vertices
function collectAllVertices(geometry, vertices) {
var i, vertex, component, len;
if (geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
vertex = new OpenLayers.Feature.Vector(this);
vertices.push(vertex);
} else {
var numVert = geometry.components.length;
if (geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing")
numVert -= 1;
for (i = 0; i < numVert; ++i) {
component = geometry.components[i];
if (component.CLASS_NAME == "OpenLayers.Geometry.Point")
vertex = new OpenLayers.Feature.Vector(component);
} else {
collectAllVertices(component, vertices);
collectAllVertices(this,vertices);
if (vertices.length > 0) {
for (ii in vertices) {
xx += vertices[ii].geometry.x;
yy += vertices[ii].geometry.y;
center = new OpenLayers.Geometry.Point(xx / vertices.length, yy
/ vertices.length);
return center;
for ModifyFeature.js:
* Method: collectDragHandle
* Collect the drag handle for the selected geometry.
collectDragHandle: function() {
var geometry = this.feature.geometry;
///var center = geometry.getBounds().getCenterLonLat();
//var originGeometry = new OpenLayers.Geometry.Point(
// center.lon, center.lat
var originGeometry = geometry.GetCenter();
var origin = new OpenLayers.Feature.Vector(originGeometry);
originGeometry.move = function(x, y) {
OpenLayers.Geometry.Point.prototype.move.call(this, x, y);
geometry.move(x, y);
this.dragHandle = origin;
this.layer.addFeatures([this.dragHandle], { silent: true });
* Method: collectRadiusHandle
* Collect the radius handle for the selected geometry.
collectRadiusHandle: function() {
var bounds = geometry.getBounds();
//var center = bounds.getCenterLonLat();
var radiusGeometry = new OpenLayers.Geometry.Point(
(bounds.right - originGeometry.x) * 1.3 + originGeometry.x,
(bounds.bottom - originGeometry.y) * 1.3 + originGeometry.y
var radius = new OpenLayers.Feature.Vector(radiusGeometry);
var resize = (this.mode & OpenLayers.Control.ModifyFeature.RESIZE);
var rotate = (this.mode & OpenLayers.Control.ModifyFeature.ROTATE);
radiusGeometry.move = function(x, y) {
var dx1 = this.x - originGeometry.x;
var dy1 = this.y - originGeometry.y;
var dx0 = dx1 - x;
var dy0 = dy1 - y;
if (rotate) {
var a0 = Math.atan2(dy0, dx0);
var a1 = Math.atan2(dy1, dx1);
var angle = a1 - a0;
angle *= 180 / Math.PI;
geometry.rotate(angle, originGeometry);
if (resize) {
var l0 = Math.sqrt((dx0 * dx0) + (dy0 * dy0));
var l1 = Math.sqrt((dx1 * dx1) + (dy1 * dy1));
geometry.resize(l1 / l0, originGeometry);
this.radiusHandle = radius;
this.layer.addFeatures([this.radiusHandle], { silent: true });
I tested it and it seems can run well.
carls wrote:
> while using ModifyFeature control on a regular polygon, it can be found
> the rotate center is not right the real center of a regular polygon? (try
> it with a regular triangle)
> additionally, while rotating and modifying a rectangle parallel to the
> axis, the control point for rotating might be at the same position of the
> right-bottom corner of the rectangle, which confuses the action of
> rotation and modifition, i.e. what i really need is to rotate the
> rectangle, but really I moved the right-bottom corner of it. This can be
> resolved if the control point becomes a little more far to the center
> point than any vertex of the geometry.
> It is not a big problem. But it will be better if imporved.
> Thanks!
Regards, Carl SHE
View this message in context: http://n2.nabble.com/ModifyFeature%3A-Rotate-Center-Point-and-Control-Point-tp1394002p1464935.html
