[OpenLayers-Users] reprojection problem [SOLVED]
Didrik Pinte
lists at dipole-consulting.com
Wed Nov 12 06:36:28 EST 2008
Hi list,
I've solved the problem by loading the data in the layer using a GeoJSON
format object with an internal and external projection defined. It works
fine now.
This does not explain why adding the features directly to the layer did
not work ...
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081112/dbd1eeda/attachment.bin
