[OpenLayers-Users] Changing the style at runtime of the WMS
Tim Schaub
tschaub at opengeo.org
Fri Nov 14 14:03:23 EST 2008
Hey-
Lucas vargas wrote:
> Hi,
> I'm trying with this code:
> basic_wms = new OpenLayers.Layer.WMS("topp:world",
> "http://localhost:8888/geoserver/wms", {
> srs: 'EPSG:4326', transparent: 'true', layers: 'topp:world',
> styles: '',
> format: format, tiled: 'true' }, {isBaseLayer: true},
> {buffer: 0});
> map.addLayers([basic_wms]);
> map.zoomToMaxExtent();
> var stationStyles = new OpenLayers.StyleMap({ // This is only
> for stations
> "default": new OpenLayers.Style({
> fillColor: "#006699",
> strokeColor: "#ff9933",
> strokeWidth: 2,
> fillOpacity: 0.6
> "select": new OpenLayers.Style({
> strokeWidth: 6,
> fillOpacity: 1
> basic_wms.mergeNewParams({ styles : stationStyles['select']});
An OpenLayers.StyleMap is used by vector layers. If you know SLD, you
can think of it as a series of user styles. When you request rendered
tiles with WMS, you are specifying a named style in your styles
parameter (or a series of named styles).
Named styles are configured on the server, user styles can be configured
on the client. So, if you knew of a named style called "somestyle" that
had been configured on the server, you could update your WMS layer to
use that:
basic_wms.mergeNewParams({styles: "somestyle"});
This would add the styles=somestyle pair to the query string in your
GetMap request.
If you want to ask your WMS to render data using some custom style, then
you have to 1) include a serialized sld:StyledLayerDescriptor element as
a SLD_BODY parameter in your query string, or 2) include a URL to an SLD
doc in the SLD parameter of your query string.
The first option is a bit of work, but can be done with the SLD format.
Alternatively, you can use a vector layer to render your data
client-side. In this case, you just give the layer the style map you
created above.
Tim
> but does not work: D
> Can anybody help me?
> Thanks.
> Lucas Vargas Eskopinski.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
