[OpenLayers-Users] Question on changing Popups on Textlayer
Dirk Umlauffd
Dirk.Umlauffd at web.de
Sun Nov 16 13:53:17 EST 2008
Am Sonntag 16 November 2008 schrieb Christopher Schmidt:
> On Sun, Nov 16, 2008 at 05:47:05PM +0100, Dirk Umlauffd wrote:
> > I feel like I read this answer already 2 or three times. But it is - in my opinion - not really the answer to my question.
> > I already use the Layer.Text and would like to improve the look and feel.
> > If the "hack" would solve the problem, could you please explain where to put the code?
> > As "patch" into Text.js?
> No. Copy the code, put it in your <script> tag.
Thanks I will give it a chance.
> > If Layer.GML is so much better, is there a tool to merge already existent textfiles into this layer?
> Yes,
> new OpenLayers.Layer.GML("My Layer",
> "filename.txt",
> {format: OpenLayers.Format.Text });
> See also: http://openlayers.org/dev/examples/sundials-spherical-mercator.html
I'm sorry, but the example uses KML Files (xml) and not plain textfiles.
http://openlayers.org/dev/examples/kml/sundials.kml
Could you please provide a correct example?
> Regards,
Best Regards
Dirk
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081116/cda6186d/attachment.html
