[OpenLayers-Users] Popups that follow the mousepointer
    Amos Hayes
    ahayes at gcrc.carleton.ca
    Mon Nov 17 10:31:40 EST 2008
Hello Trond. I was having the same problem and tried to write around
it by moving the popup corner a number of pixels horizontally and
vertically to avoid covering the point. Unfortunately, my algorithm
for guessing which quadrant the popup will appear in is flawed for
points near the very center of the map. If you can fix it or find a
better way (I have yet to feel capable enough to explore the
OpenLayers popup code), I'd love to see it. :)
Here is what I came up with:
       var popup_lonlat =
hoverFeature.geometry.getBounds().getCenterLonLat();
		if (popup_shift) {
			var shift_lon, shift_lat;
			var map_centre_lonlat = map.getCenter();
			if (popup_lonlat.lon >= map_centre_lonlat.lon) {
				shift_x = -5;
			} else {
				shift_x = 5;
			if (popup_lonlat.lat >= map_centre_lonlat.lat) {
				shift_y = 5;
			} else {
				shift_y = -5;
			var popup_pixel = map.getPixelFromLonLat(popup_lonlat);
			popup_pixel = popup_pixel.offset(new
OpenLayers.Pixel(shift_x,shift_y));
			popup_lonlat = map.getLonLatFromPixel(popup_pixel);
     	popup = new OpenLayers.Popup.AnchoredBubble("chicken",
                              popup_lonlat,
                              null,
                              feature_popup_html,
                              null, false, onPopupClose);
Amos Hayes
Geomatics and Cartographic Research Centre
Carleton University
+1.613.520.2600x8179
On 17-Nov-08, at 10:16 AM, Trond Michelsen wrote:
> Hi.
> Is it possible to get a popup to float a couple of pixels above the
> mousepointer?
> I'm using SelectFeature with hover: true to open popups, and sometimes
> the popup will open where the pointer is, which will cause the popup
> to close. Once the popup is gone, it will reopen, since the pointer is
> still hovering over the feature.
> Trond Michelsen
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
