[OpenLayers-Users] How to insert that I digitized Feture in my
WFS layer?
ironbar
joki_frei at yahoo.com
Wed Nov 19 11:02:48 EST 2008
I am working with the example vector formats example
(http://openlayers.org/dev/examples/)
I created my own wfs layer to which I would like add feature (polygon, line)
that I digitize on the viewer.
Now I want to keep most of the script of vector formats example example -
that is why I want to create function that will create wfs transaction that
is it will perform wfs insert operation to the layer that I have already
created.
So I need function that will perfrom wfs Insert transaction
Something like this:
function wfs_insrt(feature, wfsl)
var wff= new OpenLayers.Format.WFS({layerName:'topp:mywfs'},wfsl);
feature.state = OpenLayers.State.INSERT;
wff.insert(feature);
So input parameters are the feature and wfs layer and output should be
executed wfs insert transaction.
Thanks in advance
ironbar wrote:
> Dear all,
> Here is a snippet of my code:
> var wfsl= new OpenLayers.Layer.WFS( "MY WFS",
> "http://localhost/geoserver/wfs?",
> {typename: 'topp:mywfs'},
> { typename:
> 'topp:mywfs' });
> I simply want to insert the feature in my wfs layer but what I get is
> "An attempt was made to create or change an object in a way which is
> incorrect with regard to namespaces" code: 14"
> I would like simply to find a way how to perform wfs transactions using an
> imported wfs layer and feature that I created using openlayers example
> "vector-formats".
> Thank you
View this message in context: http://n2.nabble.com/How-to-insert-that-I-digitized-Feture-in-my-WFS-layer--tp1518519p1519571.html
