[OpenLayers-Users] Question on changing Popups on Textlayer
Dirk Umlauffd Dirk.Umlauffd at web.de
Wed Nov 19 14:31:43 EST 2008
Hi Christopher,
Great the markers are visible!!!
But they are completely at the wrong places!!!
If you would please have a look at the following map:
http://dtumlauffd.mine.nu/tmp_test/kopie1_textseite.html
and scroll into the map in the region of Stuttgart you will find the markers
from the region between Frankfurt an Würzburg near Stuttgart - where they should be!
I just added the fields iconSize and iconOffset with the values of 21,25 and -10,-25
Could you please find a "hack" to just modify the size of the popups and add a closebox in Layers.Text?
Would be better for me.
Worst case would be that I stay with my problems regarding the size.
Of course I then would change the h2 to e.g. h3 and so on.
Why does no one like to support and/or change anything in Layer.Text?
Regards
Dirk
Am Mittwoch 19 November 2008 schrieb Christopher Schmidt:
> On Wed, Nov 19, 2008 at 06:59:51PM +0100, Dirk Umlauffd wrote:
> > Hello Christopher,
> > The error message is gone now that I updated to 2.7 but:
> > There are no markers on the map when I use OpenLayers.Layers.GML
> Do you have iconSize and iconOffset in your textfile?
> http://trac.openlayers.org/ticket/1844
> > any help is appeciated.
> > best regards
> > Dirk
> > Am Montag 17 November 2008 schrieb Christopher Schmidt:
> > > On Mon, Nov 17, 2008 at 08:03:10PM +0100, Dirk Umlauffd wrote:
> > > > Hello Christopher,
> > > > I'm not quite sure if this will work - could you please have a look at:
> > > > http://dtumlauffd.mine.nu/tmp_test/kopie_textseite.html
> > > > The first one is working, the second one not - the second one is made with the OpenLayers.Layer.GML example.
> > > > Both with the same textfile in the same location.
> > > > With the second one I recieve:
> > > > Your browser does not support vector rendering. Currently supported renderers are:
> > > > SVG
> > > > VML
> > > > I use Firefox Version 3.0.3
> > > What version of OpenLayers? Sounds like you're out of date -- running
> > > something older than 2.6.
> > > Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081119/0c739de5/attachment.html
