[OpenLayers-Users] Selecting a feature programmatically?
Phil Maloney
pj_maloney at hotmail.com
Thu Nov 20 06:19:06 EST 2008
An OpenLayers newbie here, so apologies if I've skipped across this subject being covered else where.
I am building a large-scale mapping interface allowing users to draw and edit polygons. I want to list the polygons drawn (aka Google MyMaps style) outside the map so the user can :
- Hover list items to highlight corresponding polygons on the map
- Click a list item to switch the corresponding polygon to "edit" mode
In essence, what is required to link external HTML to a polygon feature on the map?
Code sample:
function listPolygon(event){ var html = "<a href=\"JavaScript:editPolygon('"+event.feature.id+"')\">"+event.feature.id+"</a>"; document.getElementById("polygonlist").innerHTML += html + "<br>";}
function editPolygon(e){ controls.select.select(e)}
var vectors = new OpenLayers.Layer.Vector("Vector Layer");vectors.events.on({featureadded": listPolygon});
I've attempted to use the selectControl.select method to achieve this with the feature ID...but this is obviously not the correct way of achieving this.
Any pointers appreciated.
Phil
_________________________________________________________________
See the most popular videos on the web
http://clk.atdmt.com/GBL/go/115454061/direct/01/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081120/42e2479e/attachment.html
