[OpenLayers-Users] How can we add diffrent feature sets into a
single layer?
Eric Lemoine
eric.c2c at gmail.com
Sun Nov 23 10:19:36 EST 2008
On Fri, Nov 21, 2008 at 8:53 AM, S.Reena <reena at indiamail.com> wrote:
> Is it that you want all the three point,polygon and point as a layer ?? If
> yes then a commas separated list will do as:
> var layer = new OpenLayers.Layer.WMS.Untiled(
> "Natural Resources", "http://gis.rtbi-iitm.in/cgi-bin/mapserv?",
> {map:'/var/www/html/customisation/mapfile/customNR.map',transparent:true},{layers:'NR_point,NR_polygon,NR_line'},{'displayInLayerSwitcher':false},
> {isBaseLayer:false});
This should be:
{map: "/customNR.map", transparent: true, layers:
"NR_point,NR_polygon,NR_line"},
{displayInLayerSwitcher: false, isBaseLayer: false}
layers are set in the params, and displayInLayerSwitcher and
isBaseLayer are set in the config object (one single config object!)
Eric
