[OpenLayers-Users] Cluster Layers - Correct placemark format?
Christopher Schmidt
crschmidt at metacarta.com
Mon Nov 24 10:45:55 EST 2008
On Mon, Nov 24, 2008 at 03:44:40PM +0000, Allan Henderson wrote:
> Hi there,
> I'm trying to implement a Cluster layer from a KML feed. The feed on
> it's own is working fine but all falls apart when I try a cluster
> strategy. So I'm thinking this method doesn't work
It should. Are you using a strategy.Fixed? Can you share your code?
Regards,
Christopher Schmidt
MetaCarta
