[OpenLayers-Users] DrawFeature and FeatureAdded event
Lehtonen, Mika
mika at digikartta.net
Mon Nov 24 13:58:53 EST 2008
Hej Sture,
I have a little bit similar application and I am using the following
event handler. It seems to be working just fine.
vlayer.events.on({"featureadded": offBuffer, "featureunselected":
offBuffer});
vlayer is the vector layer, offBuffer function for added feature event
(+ for unselected feature).
- mika -
Sture Dingsøyr kirjoitti:
> Hi all
> Have made a control in OL that allows the user to draw a regular polygon. Have also added an event that uses the "featureadded" event.
> But...when the user only click in the map..a small polygon is drawed, but the event trigger is not fired..
> If the user draws a "larger" polygon the trigger fires just fine...
> Any suggestions?
> My ol code is this:
> var myVector = new OpenLayers.Layer.Vector("My vector");
> map.addLayer(myVector);
> var findRectangle = new OpenLayers.Control.DrawFeature(
> myVector,
> OpenLayers.Handler.RegularPolygon,
> title: "Klikk eller dra ut firkant rundt objekt i kartet for å finne mer informasjon",
> handlerOptions: {sides: 4, irregular: true},
> displayClass: 'findRectangle'
> findRectangle.events.register('featureadded', findRectangle, findRectangleFeaturAadded);
> function findRectangleFeaturAadded(feature) {
> alert(feature);
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
