[OpenLayers-Users] DrawFeature and FeatureAdded event
Lehtonen, Mika
mika at digikartta.net
Tue Nov 25 01:41:39 EST 2008
Ok,
that's right. Sorry for mixing things up. Anyway the possible bug
doesn't seem to be occuring in that latter method.
- mika -
Eric Lemoine kirjoitti:
> Mika,
> Sture registers a listener on the draw feature control's featureadded
> event, not on the layer's. The former is triggered only when a feature
> is added as a result of feature drawn by the user through the draw
> feature control. The latter is triggered every time a feature is added
> to the layer, whatever the way the feature was created.
> Eric
> 2008/11/24, Lehtonen, Mika <mika at digikartta.net>:
>> Hej Sture,
>> I have a little bit similar application and I am using the following
>> event handler. It seems to be working just fine.
>> vlayer.events.on({"featureadded": offBuffer, "featureunselected":
>> offBuffer});
>> vlayer is the vector layer, offBuffer function for added feature event
>> (+ for unselected feature).
>> - mika -
>> Sture Dingsøyr kirjoitti:
>>> Hi all
>>> Have made a control in OL that allows the user to draw a regular polygon.
>>> Have also added an event that uses the "featureadded" event.
>>> But...when the user only click in the map..a small polygon is drawed, but
>>> the event trigger is not fired..
>>> If the user draws a "larger" polygon the trigger fires just fine...
>>> Any suggestions?
>>> My ol code is this:
>>> var myVector = new OpenLayers.Layer.Vector("My vector");
>>> map.addLayer(myVector);
>>> var findRectangle = new OpenLayers.Control.DrawFeature(
>>> myVector,
>>> OpenLayers.Handler.RegularPolygon,
>>> title: "Klikk eller dra ut firkant rundt objekt i kartet for å finne mer
>>> informasjon",
>>> handlerOptions: {sides: 4, irregular: true},
>>> displayClass: 'findRectangle'
>>> findRectangle.events.register('featureadded', findRectangle,
>>> findRectangleFeaturAadded);
>>> function findRectangleFeaturAadded(feature) {
>>> alert(feature);
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
