[OpenLayers-Users] DrawFeature and FeatureAdded event
Eric Lemoine
eric.c2c at gmail.com
Tue Nov 25 04:17:28 EST 2008
On Tue, Nov 25, 2008 at 8:49 AM, Sture Dingsøyr <candalt at online.no> wrote:
> Hi Mika and Eric...thanx for quick response :-)
> Have published an example on http://www.avinet.no/bugopenlayers/openlayers-2.7/examples/modify-feature.html
> Have added a control button to draw the regular polygon.
> ...if the user just clicks (no mouse movement between up and down) the feature is added to the layer, but the featureadded event is not triggered (should produce a javascript alert)..
> So the problem is that the featureadded event does not fire in this case.
> Have added events to both the layer and control...and it sems to me that in none of the cases the event is triggered.
> Try the example...(just click in the map).
I created a ticket and attached a patch to it. Could you give it a try?
<http://trac.openlayers.org/ticket/1857>
Eric
