[OpenLayers-Users] changing style of a WFS layer
Lehtonen, Mika
mika at digikartta.net
Tue Nov 25 09:23:57 EST 2008
Hi Alexandre,
interesting example.
My problem is that I can't figure out how to force the wfs layer to read
the new style parameters after the user has clicked zoom button. I have
tried all sorts of, occassionaly desperate, methods for make it to do
that. Like mergeNewParams and redraw. I switched them for example to
map.event listener and tried to listen to any "sounds" of zooming; like
zoomend. And those listeners sure did trigger the functions they were
to, but the wfs layer stayed with the same style. I guess the easiest
variable to use here, would be map.getZoom( ).
- mika -
Alexandre Dube kirjoitti:
> Hi,
> Take a look at this example :
> http://dev.openlayers.org/sandbox/vector-behavior/examples/strategy-cluster.html
> You could try to change the radius : function(feature) using
> feature.layer.map.zoom
> Alexandre
> Lehtonen, Mika wrote:
>> Hi,
>> probably I'm asking something that's been asked for several times,
>> but I just couldn't find the answer.
>> I have a WFS layer which has points. My intention is to render those
>> points with a style depending on the zoom level. So more you zoom in,
>> bigger the points should be. I have styleMap defined in my wfs layer
>> definition. I tried to do dynamic out of it, but didn't succeed. Even
>> if I redraw my wfs layer, the styles defined at the first place stays.
>> So, what would be a proper approach in this challenge?
>> Here's my "static" code:
>> shpStyle = new OpenLayers.StyleMap({
>> pointRadius: 3,
>> strokeColor: "red",
>> strokeWidth: 1,
>> strokeOpacity: 1,
>> fillColor: 'black',
>> fillOpacity: 0.2
>> fserver = new OpenLayers.Layer.WFS("Uploaded SHP",
>> "http://10.8.0.1:8080/cgi-bin/featureserver-1.12/featureserver.cgi/shape?format=WFS",
>> {typename: "KUNTA"},{extractAttributes: false, projection: new
>> OpenLayers.Projection("EPSG:2393"), styleMap: shpStyle});
>> - mika -
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
