[OpenLayers-Users] maximum ZoomLevel for google maps
Rodolfo Moreno
rmoreno at voxiva.com
Tue Nov 25 10:49:07 EST 2008
I Reena Alexandre is right. I have tested your suggestion and it has not
fixed my issue.
maybe to be a constraint of google maps?
Alexandre Dube wrote:
> Google layers already have fixed resolutions, so using fixed scales will
> not help in this case.
> Alexandre
> S.Reena wrote:
>> Hi Rodolfo,
>> I am not using google maps as base , I have made my own base layer..but
>> for
>> your case playing with the scale would serve the purpose
>> I did like this ,
>> map = new OpenLayers.Map('map',{ scales:
>> [5000000,2000000,1000000,500000,200000,100000,50000,20000,10000,5000,2000,1000],numZoomLevels:
>> 12, maxResolution: "auto",projection: "EPSG:4326", controls: [] });
>> Reena
>> Rodolfo Moreno wrote:
>>> Hi all,
>>> I am using openlayers for showing my mapguide layers and google maps as
>>> base
>>> layer.
>>> my problem is that the "zoom in" this limited until a certain scale. In
>>> my
>>> case the maximum scale that I can achieve is 1:18k (this is what the map
>>> shows).
>>> I did a comparison with the own google maps GUI
>>> (http://maps.google.com/)
>>> and I have seen that to my sample application lack it 4 zoom levels in
>>> order
>>> to achieve the maximum scale.
>>> So I was reviewing the openlayers documentation and I found this
>>> link(http://trac.openlayers.org/wiki/SettingZoomLevels).
>>> I did some change in my code like this:
>>> var satellite = new OpenLayers.Layer.Google(
>>> "Google Satellite" , {type: G_NORMAL_MAP}, {
>>> minZoomLevel:
>>> 0, maxZoomLevel: 30}
>>> but even it doesn't work as I want.
>>> I appreciate all idea
>>> Regards
>>> Rodolfo Moreno
>>> CivilEng
>>> View this message in context:
>>> http://n2.nabble.com/maximum-ZoomLevel-for-google-maps-tp1574304p1574304.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/maximum-ZoomLevel-for-google-maps-tp1574304p1576820.html
