[OpenLayers-Users] lines crossing the 180/dateline not working. wrapDateLine not helping.
Phil Scadden p.scadden at gns.cri.nz
Wed Nov 26 21:03:46 EST 2008
I have a source layer (in ArcSDE) which has arc lines that cross the 180
line. Creating a WMS on this, I can see lines on both sides with
wrapDateLine set to true,but lines that actually cross the dateline are
a mess. Because the lines in ArcSDE are input to various processing
jobs, I am very
loathe to actually split the lines as this would break a no. of
applications. Making a copy with the
splits created is an option but messy for maintenance.
1/ Is there a work around short of splitting it?
2/ If not, where in openlayers does the problem occur (as a hint), so I
might look at the code for
a solution?
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
