[OpenLayers-Users] OL-Based GeoEditor
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Nov 28 17:37:30 EST 2008
Hi Brad,
what exactly do you want to get hold of?
The server-side software resides here:
http://code.google.com/p/webprocessingserver/
The javascript code is all in the web page when you use view source.
http://crschmidt.net/mapping/wpserverdemo/
Best regards,
Bart
Brad Spencer wrote:
> Bart,
> This looks just like the tools that I need. Do you know how I can get hold of these function?
> Cheers, Brad...
> -----Original Message-----
> From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
> Sent: Friday, November 28, 2008 11:13 PM
> To: Brad Spencer
> Cc: 'Yves Moisan'; users at openlayers.org; dev at openlayers.org
> Subject: Re: [OpenLayers-Users] OL-Based GeoEditor
> AFAIK there is no javascript library for this.
> As Carsten writes they use a Java backend based on JTS for this, which is
> a pretty logical solutions.
> If you look at the WPSDemo by Chris you'll see something similar. which
> uses Python and GEOS on the server-side.
> Best regards,
> Bart
>> Yves,
>> This sounds interesting. I have a need to select a group or collection of
>> polygons from a user who just clicks the polygons they need. Then I need
>> to aggregate all the geometries into a single object and also aggregate
>> the numeric attributes. Then to insert the new geometry into the database
>> as a WFS-T transaction. So far my OL application can get all the polygons
>> and all the attributes with WFS but have not got software to aggregate the
>> geometries. Would you have the javascript software to do this?
>> Cheers, Brad…
>> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> On Behalf Of Dipl. Inf. Carsten Eider
>> Sent: Friday, November 28, 2008 9:13 PM
>> To: Yves Moisan
>> Cc: users at openlayers.org; dev at openlayers.org
>> Hi Yves,
>> thank you for your answer, i  hope other people also had some fun with
>> this nice tool!
>> What ist your impresiion of it? Could it be usable?
>> Are there any other testers or has someone else a feedback (either
>> negative or positive) for me?
>> English UI: Our development-focus is set on german farmers, so there is no
>> need to use an english one!
>> But if there is a big demand for it, i will do it, or better let it do:-)
>> thx Carsten
>> Yves Moisan schrieb:
>> I like the gröSSe option :-).  An English UI would help me as a French
>> speaker.  Mein Deutsch nicht sehr gut ist :-)
>> Yves
>> Le jeudi 27 novembre 2008 Ã  15:44 +0100, Dipl. Inf. Carsten Eider a
>> écrit :
>> Hi list,
>> my work on a GeoEditor is nearly completely done.
>> Features:
>>       * using Openlayers for geometric operations, only joining and
>>         splitting is done by a JTS-Java-Backend
>>       * using WFS-T with a GeoServer(Shapefile as backend) for storing
>>         the changes
>>       * using SLD and handmade Java-BackEnd for storing LayerStyles
>>       * using dojo for editing styles.
>> Restrictions:
>>       * only german front-end
>> Proof-of-concept:
>>       * https://143.93.78.98/geoEditor2/editor.html, use "demo" and no
>>         password for login
>> Thx Carsten
>> Dipl. Inf. Carsten Eider schrieb:
>> Hi folks,
>> i am working on a small geo-editor for an agricultural project in
>> rhine-palatinat/germany, visit http://www.agroconnect.de for more
>> information.
>> Upto now my editor has the following features:
>>       * new polygon, plain OL
>>       * edit polgon, plain OL
>>       * delete polygon, plain OL
>>       * union polygon, OL with a javaserver in the backend
>> Coming feaures:
>>       * split polygon into 2 elements, OL with server backend
>>       * group polygons
>> At the moment i am hanging a bit with the split-feature.
>> My idea is
>>      1. select polygon
>>      2. select first point/vertix as starting point
>>      3. select second point as ending point
>>      4. do split
>>      5. remove polygon and add the new ones
>> Step 4 will be done on serverside,but could also be done on
>> clientside.
>> Any ideas how to realize steps 1-3. Should i use several controls
>> (Select and Modify) or
>> should i subclass Control.ModifyFeature ?
>> Any hints will be appreciated.
>> Mit freundlichen Grüßen / Yours faithfully
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Kompetenzzentrum für Innovative Informationssysteme
>> c/o Fachhochschhule Bingen / University of applied sciences Bingen
>> Berlinstraße 109
>> 55411 Bingen
>> Tel: +49 (0) 6721 / 409-179
>> Fax: +49 (0) 6721 / 409-158
>> email: eider at fh-bingen.de
>> Internet: iis.fh-bingen.de
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Berlinstraße 109
>> 55411 Bingen
>> Users mailing list
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Berlinstraße 109
>> 55411 Bingen
>> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
