[OpenLayers-Users] Aligning mapserver wms layer with google
maps again
Christopher Schmidt
crschmidt at metacarta.com
Wed Oct 1 03:00:25 EDT 2008
On Tue, Sep 30, 2008 at 10:59:30PM -0700, bmrg wrote:
> I am not sure if this is an issue with projections or what, but I am having a
> peculiar problem trying to align my mapserver wms layer with a google layer.
> I have tried playing around with projections ect. to try and remedy this but
> to no avail.
You need to be using sphericalMercator. (Your server will need to
support EPSG:900913.) Set the sphericalMercator option on your Google
Map.
Start with that, and then comment on how you're having problems getting
that working.
-- Chris
> The misalignment seems to depend on the latitude of the feature. Features
> drawn at the central latitude of the map align very well and the
> misalignment increases the further north or south of the map centre. This is
> even the case when I reposition the map. The wms layers are compresses in
> the north-south dimension.
> Is it obvious to anyone what I may be doing wrong? I have attahced part of
> the openlayers script below for reference.
> map = new OpenLayers.Map( 'map', {
> numZoomLevels: 20, maxZoomLevel: 20 });
> var gsat = new OpenLayers.Layer.Google(
> "Google Satellite",
> {type: G_SATELLITE_MAP}
> //map.addLayer(gsat);
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: G_PHYSICAL_MAP}
> //map.addLayer(gphy);
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets" // the default
> //map.addLayer(gmap);
> var ghyb = new OpenLayers.Layer.Google(
> "Google Hybrid",
> {type: G_HYBRID_MAP}
> //map.addLayer(ghyb);
> map.addLayers([gsat, gphy, gmap, ghyb]);
> wms = new OpenLayers.Layer.MapServer( "Regional
> Ecosystems",
> "http://localhost/cgi-bin/mapserv.exe", {map:
> 'C:/ms4w/Apache/htdocs/re.map', transparent: 'true', format: 'png'},
> {'isBaseLayer': false, 'opacity': 0.5, 'reproject':
> true, 'gutter': 15, 'singleTile': true} );
> map.addLayer(wms);
> cadastre = new OpenLayers.Layer.MapServer( "Cadastre",
> 'C:/ms4w/Apache/htdocs/cadastre.map', transparent: 'true', format: 'png'},
> map.addLayer(cadastre);
> cad_label = new OpenLayers.Layer.MapServer( "Cadastre Labels",
> 'C:/ms4w/Apache/htdocs/cad_label.map', transparent: 'true', format: 'png'},
> map.addLayer(cad_label);
> wms.setVisibility(false);
> cadastre.setVisibility(false);
> cad_label.setVisibility(false);
> View this message in context: http://www.nabble.com/Aligning-mapserver-wms-layer-with-google-maps-again-tp19754401p19754401.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
