[OpenLayers-Users] OL code JS (ECMA?) standarts compliance and code packing
Paul Spencer pagameba at gmail.com
Sat Oct 4 11:34:00 EDT 2008
Darn, there are three missing semi-colons in 2.7 release version:
Format/GML/Base.js line 456
Format/GML/v3.js lines 144 and 149
I've run jslint on the code base for 2.6 and for the RCs in 2.7 but I
missed running it on the final release I guess.
Cheers
Paul
On 3-Oct-08, at 4:08 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> I use packer as well. The main problem is that packer put everything
> on one line.
> This causes problems because of missing semicolons (function endings
> I think?).
> For some reason, the regular packing tools for OpenLayers does not
> combine the faulty lines.
> The easiest way to find these problems is to take the OpenLayers.js
> file and remove all linefeeds.
> The problem is then tracking it back to the file that created the
> problem.
> I would give you my patch, but it is for OL 2.5, so not much use.
> When I upgrade to 2.7, I will try to make a single patch for the
> missing semicolons, and submit it.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Christopher Schmidt skrev:
>> On Thu, Oct 02, 2008 at 05:55:37AM -0700, BrainDrain wrote:
>>> I think that code strictness is not such a bad property.
>> Are you saying that the OL code fails JSLint? It doesn't seem to
>> for me
>> at the moment. If that's the case, please offer at least data about
>> how
>> to reproduce it or what error you're getting, and preferably with a
>> patch.
>>> Paul Spencer-5 wrote:
>>>> I periodically run jslint on the openlayers code base and commit
>>>> changes to fix things like missing semi-colons.  I haven't had any
>>>> problems using jsmin or the YUI compressor.  I haven't tried Packer
>>>> for a while, I have a fundamental dislike of the approach he takes
>>>> (using eval() to load the code) but that is mostly a personal
>>>> opinion.
>>>> Cheers
>>>> Paul
>>>> On 2-Oct-08, at 8:31 AM, BrainDrain wrote:
>>>>> HI
>>>>> Why well-known js packer (http://dean.edwards.name/packer/) breaks
>>>>> OL code?
>>>>> It becomes unworking.
>>>>> I've tried online and c# versions of this packer (and some
>>>>> others from
>>>>> codeproject). Results - the same.
>>>>> It turned out, that not all of my code is compatible with this
>>>>> packer and I
>>>>> tried to test it with JSLint.
>>>>> After some revision with the help of JSLint I achieved a success
>>>>> (for my
>>>>> code).
>>>>> But what about OL? base62 encoding has good compression ratio -
>>>>> almost 50%
>>>>> Paul
>>>>> View this message in context:
>>>>> http://www.nabble.com/OL-code-JS-%28ECMA-%29-standarts-compliance-and-code-packing-tp19778306p19778306.html
>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> View this message in context: http://www.nabble.com/OL-code-JS-%28ECMA-%29-standarts-compliance-and-code-packing-tp19778306p19778713.html
>>> Users mailing list
> Users mailing list
