[OpenLayers-Users] open popup in open layers from external list
Bijoy K. Anupam
bijoya at rediff.co.in
Mon Oct 6 03:04:19 EDT 2008
Hi Leo,
I exactly have the same problem. And, I don't know if this can be done.
Currently, my work is on hold in this direction :-(
If you find any solution on this, please share this with me too... :)
<BIJOY>
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Leo
Sent: Sunday, October 05, 2008 6:27 PM
To: users at openlayers.org
Subject: [OpenLayers-Users] open popup in open layers from external list
Hi to all, I have a map with a lot of marker. Every marker is added by the
function at the bottom. All works very well and i can see all marker in the
map with its popup if i click on it. Now I would create a popup window with
an html list of all markers in the map and if i click an item i want the
marker associated in the map opens its popup.
I've looked in the example, but i can't find the solution. Is there a way to
do what i need?
Thank you very much for your help!
function addMarker(ll, popupClass, popupContentHTML, closeBox, overflow,
iconID) {
var size = "";
var offset = "";
var icon = "";
switch (iconID)
case 1:
size = new
OpenLayers.Size(17,29);
offset = new OpenLayers.Pixel(-(size.w/2),
-size.h);
icon = new
OpenLayers.Icon(\'./templates/images/GREEN.png\',size,offset);
}break;
case 2:
size = new
OpenLayers.Size(8,8);
-size.h);
icon = new
OpenLayers.Icon(\'./templates/images/listitem.png\',size,offset);
}break;
case 3:
size = new
-size.h);
icon = new
OpenLayers.Icon(\'./templates/images/RED.png\',size,offset);
}break;
default:
size = new
-size.h);
icon = new
OpenLayers.Icon(\'./templates/images/AQUA.png\',size,offset);
}break;
var feature = new
OpenLayers.Feature(markers, ll, {icon: icon});
feature.closeBox = closeBox;
feature.popupClass = popupClass;
feature.data.popupContentHTML = popupContentHTML;
feature.data.overflow = (overflow) ? "auto" : "hidden";
var marker = feature.createMarker();
var markerClick = function (evt) {
if (this.popup == null) {
this.popup = this.createPopup(this.closeBox);
map.addPopup(this.popup);
this.popup.show();
} else {
this.popup.toggle();
currentPopup = this.popup;
OpenLayers.Event.stop(evt);
marker.events.register("mousedown", feature,
markerClick);
markers.addMarker(marker);
View this message in context:
http://n2.nabble.com/open-popup-in-open-layers-from-external-list-tp1298733p
1298733.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
