[OpenLayers-Users] [ZS1] Re: OL code JS (ECMA?) standarts
compliance and code packing
Frédéric Junod
frederic.junod at camptocamp.com
Mon Oct 6 06:18:31 EDT 2008
I opened a ticket to fix these bugs:
http://trac.openlayers.org/ticket/1762
fredj
Le Mon, 06 Oct 2008 11:51:29 +0200,
"Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk> a écrit :
> I have just tested with trunk, and there is also a missing semicolon in
> Util.js line 1272.
> In the OpenLayers.js compressed file, this becomes line 189.
> Adding the semicolon to the end of line 189 allows me to pack OpenLayers.js.
> If someone is using the .Net version of Packer, change the function:
> private string unescapeMatch(Match match)
> return "\\" + escaped[unescapeIndex++];
> To:
> return "\\" + match.Value;
> Otherwise it will throw some "Index out of bounds" exception.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Paul Spencer skrev:
> > Darn, there are three missing semi-colons in 2.7 release version:
> > Format/GML/Base.js line 456
> > Format/GML/v3.js lines 144 and 149
> > I've run jslint on the code base for 2.6 and for the RCs in 2.7 but I
> > missed running it on the final release I guess.
> > Cheers
> > Paul
> > On 3-Oct-08, at 4:08 AM, Kenneth Skovhede, GEOGRAF A/S wrote:
> >> I use packer as well. The main problem is that packer put everything
> >> on one line.
> >> This causes problems because of missing semicolons (function endings
> >> I think?).
> >> For some reason, the regular packing tools for OpenLayers does not
> >> combine the faulty lines.
> >> The easiest way to find these problems is to take the OpenLayers.js
> >> file and remove all linefeeds.
> >> The problem is then tracking it back to the file that created the
> >> problem.
> >> I would give you my patch, but it is for OL 2.5, so not much use.
> >> When I upgrade to 2.7, I will try to make a single patch for the
> >> missing semicolons, and submit it.
> >> Christopher Schmidt skrev:
> >>> On Thu, Oct 02, 2008 at 05:55:37AM -0700, BrainDrain wrote:
> >>>> I think that code strictness is not such a bad property.
> >>> Are you saying that the OL code fails JSLint? It doesn't seem to for me
> >>> at the moment. If that's the case, please offer at least data about how
> >>> to reproduce it or what error you're getting, and preferably with a
> >>> patch.
> >>>> Paul Spencer-5 wrote:
> >>>>> I periodically run jslint on the openlayers code base and commit
> >>>>> changes to fix things like missing semi-colons. I haven't had any
> >>>>> problems using jsmin or the YUI compressor. I haven't tried Packer
> >>>>> for a while, I have a fundamental dislike of the approach he takes
> >>>>> (using eval() to load the code) but that is mostly a personal
> >>>>> opinion.
> >>>>> Cheers
> >>>>> Paul
> >>>>> On 2-Oct-08, at 8:31 AM, BrainDrain wrote:
> >>>>>> HI
> >>>>>> Why well-known js packer (http://dean.edwards.name/packer/) breaks
> >>>>>> OL code?
> >>>>>> It becomes unworking.
> >>>>>> I've tried online and c# versions of this packer (and some others
> >>>>>> from
> >>>>>> codeproject). Results - the same.
> >>>>>> It turned out, that not all of my code is compatible with this
> >>>>>> packer and I
> >>>>>> tried to test it with JSLint.
> >>>>>> After some revision with the help of JSLint I achieved a success
> >>>>>> (for my
> >>>>>> code).
> >>>>>> But what about OL? base62 encoding has good compression ratio -
> >>>>>> almost 50%
> >>>>>> Paul
> >>>>>> View this message in context:
> >>>>>> http://www.nabble.com/OL-code-JS-%28ECMA-%29-standarts-compliance-and-code-packing-tp19778306p19778306.html
> >>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >>>>>> _______________________________________________
> >>>>>> Users mailing list
> >>>>>> Users at openlayers.org
> >>>>>> http://openlayers.org/mailman/listinfo/users
> >>>>> Users mailing list
> >>>> http://www.nabble.com/OL-code-JS-%28ECMA-%29-standarts-compliance-and-code-packing-tp19778306p19778713.html
> >>>> Users mailing list
> >> Users mailing list
> Users mailing list
Frédéric Junod
Camptocamp SA
