[OpenLayers-Users] OpenLayers.DOTS_PER_INCH as global setting seems shouldn't be changed just for only mapguide layer while other layers added together
Carl carlshe at 163.com
Tue Oct 7 11:57:16 EDT 2008
>From Openlayers document, it can be found:
 MapGuide OS uses a DPI value and degrees to meters conversion
 factor that are different than the defaults used in OpenLayers, so these
must be adjusted accordingly in  your application.  See the MapGuide example
for how to set these values for MGOS.
>From mapguide.html, it can be found:
       var metersPerUnit = 111319.4908;  //value returned from mapguide
        var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
        OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
        OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
        OpenLayers.DOTS_PER_INCH = 96;
it seems both OpenLayers.INCHES_PER_UNIT and OpenLayers.DOTS_PER_INCH are
global settings.
I doubt if two different layers, such as WMS and MapGuide are added to
Openlayers Map, the above settings will influence both layers. but it seems
the settings shouldn't be changed for WMS?
View this message in context: http://www.nabble.com/OpenLayers.DOTS_PER_INCH-as-global-setting-seems-shouldn%27t-be-changed-just-for-only-mapguide-layer-while-other-layers-added-together-tp19861382p19861382.html
