[OpenLayers-Users] animate panning problem
Simo D simone.dalmasso at gmail.com
Wed Oct 8 09:18:30 EDT 2008
Perfect! Thanks a lot!
Simone
Pierre GIRAUD wrote:
> What about calling map.panTo which should do the job for you ?
> http://dev.openlayers.org/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.panTo
> Regards,
> Pierre
> On Wed, Oct 8, 2008 at 12:36 PM, Simo D <simone.dalmasso at gmail.com> wrote:
>> Hi, I'm trying to use an animated panning on a map using
>> OpenLayers.Tween.
>> What I want is that the map recenter where I've clicked. The animation
>> works
>> but the movement is exagerate and strange. My code is:
>> var tween, events;
>>            tween = new OpenLayers.Tween(OpenLayers.Easing.Linear.easeIn);
>>            events = new OpenLayers.Events(null,
>> OpenLayers.Util.getElement('map'), null, true);
>>            events.register("click", null, moveMap);
>>        function moveMap(e) {
>>            var viewport = OpenLayers.Util.getElement('map');
>>            var mapCenter = map.getPixelFromLonLat(map.getCenter());
>>            var viewportPosition = OpenLayers.Util.pagePosition(viewport);
>>            e.xy = events.getMousePosition(e);
>>            var from = {
>>                x: mapCenter.x+viewportPosition[0],
>>                y: mapCenter.y+viewportPosition[1]
>>            var to = {
>>                x: e.xy.x,
>>                y: e.xy.y
>>                                                var callbacks = {
>>                                                      eachStep:
>> function(value) {
>> map.setCenter(map.getLonLatFromPixel(new
>> OpenLayers.Pixel(value.x-viewportPosition[0],
>> value.y-viewportPosition[1])));
>>            var duration = 50;
>>                                                tween.start(from, to,
>> duration, {callbacks: callbacks});
>> Thanks for any help.
>> Simone
>> View this message in context:
>> http://www.nabble.com/animate-panning-problem-tp19876306p19876306.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/animate-panning-problem-tp19876306p19878547.html
