[OpenLayers-Users] Error retrievin data with Ajax
ajohnson at ecotropolis.com
Thu Oct 9 17:24:09 EDT 2008
>Nevermind. I just did a little more research and found that there is more
than one version of mod_jk.so in the download directory. I had the one
for Apache 2.0, not the one for Apache 2.2. Thanks very much and sorry
for the extra emails.
Amy
>> Hi Amy!
>> You can install the jk-connector... wich is a Tomcat connector...
>> This connector will make your apache "talk to" tomcat (or the geoserver
>> istance of it... see documentation:
>> http://tomcat.apache.org/connectors-doc/)...
>> I've got the same problem a little time ago and installed Apache +
>> Tomcat
>> JK_Connector and it works fine...
>> Oh.. there're still some errors in my geoserver configuration, because
>> some
>> parts
>> of it only works on port 8080.. but to solve exactally your problem,
>> this
>> should work!
>> Regards,
>> Rodrigo
>> Rodrigo C. Antonialli
>> Rio Claro - SP - Brasil
>> LinkedIn: http://www.linkedin.com/in/rcaprofile
>> Contato: (19) 9757-0370
>> rca.cirdan at gmail.com
>> rcantonialli at gmail.com
>> Skype: rc_antonialli
>> On Wed, Oct 1, 2008 at 14:49, <ajohnson at ecotropolis.com> wrote:
>>> I getting the following error:
>>> Access to restricted URI denied" code: "1012"
>>> when trying to retrieve information from a WMS. I have the whole thing
>>> set
>>> up on my machine, but I am making the Openlayers request through Apache
>>> (on port 9000) to Geoserver running on Tomcat (port 8080). I researched
>>> the error and I am getting it because I am trying to retrieve
>>> information
>>> from a different domain than I am calling from. Is there a way around
>>> that?
>>> Thanks,
>>> Amy
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
