[OpenLayers-Users] kml projection
Eric Lemoine
eric.c2c at gmail.com
Fri Oct 10 13:02:23 EDT 2008
Hi. Since you yourself create the KML format the format and projection
options passed to the vector layer are useless. To make the KML format
do the re-projection try:
var format = new OpenLayers.Format.KML({
internalProjection: new OpenLayers.Projection("ESPG:900913"),
externalProjection: new OpenLayers.Projection("ESPG:4326")
Eric
2008/10/10, Saris Hein <hein at beta9.be>:
> Hi,
> I am trying to show an inline kml string onto a OSM layer (using the
> proper projection transformations).
> Everything seems to work, except the features in the KML string are
> not shown properly.
> I use this code:
> function init(){
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:
> 4326"),
> units: "km",
> numZoomLevels: 18,
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
> 20037508, 20037508.34)
> map = new OpenLayers.Map('map', options);
> // create OSM layer
> var mapnik = new OpenLayers.Layer.TMS(
> "OpenStreetMap (Mapnik)",
> "http://a.tile.openstreetmap.org/",
> type: 'png', getURL: osm_getTileURL,
> displayOutsideMaxExtent: true,
> attribution: '<a href="http://
> www.openstreetmap.org/">OpenStreetMap</a>'
> map.addLayer(mapnik);
> // Add a KML as inline String
> var kmlString = '<?xml version="1.0" encoding="UTF-8"?><kml
> xmlns="http://earth.google.com/kml/2.1
> "><Document><Style
> id="marker"><IconStyle><Icon><href>http://localhost:3000/openlayers/img/marker-green.png
> </href></Icon></IconStyle></Style><Placemark id="13856"><name>place
> name</name><description>NULL::character varying</
> description><styleUrl>#marker</
> styleUrl><Point><altitudeMode>relativeToGround</
> altitudeMode><coordinates>23.29555556,-17.98611111</coordinates></
> Point></Placemark><Placemark id="13852"><name>place name 2</
> altitudeMode><coordinates>24.56638889,-17.54027778</coordinates></
> Point></Placemark></Document></kml>';
> kmlLayer = new OpenLayers.Layer.Vector("KML", {
> projection: new OpenLayers.Projection("EPSG:4326"),
> format: OpenLayers.Format.KML,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true
> var kmlParser = new OpenLayers.Format.KML();
> var kmlFeatures = kmlParser.read(kmlString);
> kmlLayer.addFeatures(kmlFeatures);
> map.addLayer(kmlLayer);
> bounds = getFeaturesBounds(kmlLayer.features);
> map.zoomToExtent(bounds.transform(map.displayProjection,
> map.getProjectionObject()));
> When I read the same KML from a file and use this code, the data is
> shown correctly:
> kmlLayer = new OpenLayers.Layer.GML("KML", "kml/data.kml",
> formatOptions: {
> My guess is that I should do something else to add the features to the
> kmlLayer. Like a projection maybe?
> Thanks for your time.
> Hein Saris - mailto:hein at beta9.be
> Beta Nine - software engineering - http://www.beta9.be
> .Mac - heinsaris at mac.com - http://homepage.mac.com/heinsaris
> Skype: heinsaris
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
