[OpenLayers-Users] Dynamically Sized Points With Styles
Arnd Wippermann
arnd.wippermann at web.de
Fri Oct 10 14:25:53 EDT 2008
The resolution is units per pixel. if you want a point with a radius of 20km
= 20000m, then you can calculate the radius in pixel = 20000 / actual
resolution.
Instead of a point feature, you can also take a regular polygon with ie. 20
sides to get a circle. Then the radius have to be in units of the map and as
it is a geometric object, it changes the size with zoom.
Arnd Wippermann
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Chris Streeter
Gesendet: Freitag, 10. Oktober 2008 19:09
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Dynamically Sized Points With Styles
As a followup to this question, I'm trying to wrap my head around how to
translate actual distances to what is shown on the map. For example, if I
wanted to create a feature with a radius of 20 kilometers, how do I specify
the radius for the feature based on the map's resolution and scale. I'm not
quite clear on how feature radii relate to map resolution and scale.
Thanks,
- Chris
On Wed, Oct 8, 2008 at 11:49, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
http://n2.nabble.com/GML%2C-Point-and-Change-the-Size-of-the-Circle...-tc791
275.html#a791275
listen to the zoom event and redraw the feature with the new styleMap, where
the pointRadius is a function of the zoom level:
new OpenLayers.StyleMap({
"default": OpenLayers.Util.applyDefaults({
pointRadius: faktor*map.getZoom()
}, OpenLayers.Feature.Vector.style["default"]
Arnd Wippermann
_____
Gesendet: Mittwoch, 8. Oktober 2008 07:04
Betreff: [OpenLayers-Users] Dynamically Sized Points With Styles
I was wondering if it is possible to dynamically resize a point based on the
zoom level of the map.
With the example at
http://www.openlayers.org/dev/examples/styles-unique.html, can we make the
points change their radius as we zoom in? I'd like to keep the circles the
same relative size to the underlying map layer.
Thanks,
- Chris
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081010/6c8adc39/attachment.html
