[OpenLayers-Users] FeatureVector and atPoint() function way
off. Why??
Eric Lemoine
eric.c2c at gmail.com
Tue Oct 14 00:38:49 EDT 2008
Hi. atPoint() is an approximation based on the bounds of the geometry.
Instead you can use poly.containsPoint(point), where point is a
Geometry.Point object derived from the LonLat object. Eric
2008/10/14, plen <peteralen at earthlink.net>:
> Hello,
> I have created some polygons through the DrawFeature and saw that there is
> an atPoint() for both the OpenLayers.Feature.Vector and the feature vectors
> geometry property. When I register a click event for the map, I get the
> lat/long for the point clicked via:
> map.events.register("click", map, function(e) {
> var lonlat = map.getLonLatFromViewPortPx(e.xy);
> When I use that lonlat to see if the click was on one of my features, I do
> the following for each of my features:
> if (feature.atPoint(lonlat)) {
> The problem is that the statement is true even when I click well outside of
> any of the features. It typically is "true" whenever I click inside the
> features, but it also is true in alot of areas outside as well.
> Does anyone know why this is? I see that there is some optional tolerance
> parameters for the atPoint() function, but I dont know what those values
> would be. Is there some trick to getting this function to work properly or
> is a crap shoot.
> Thanks for any insight - Peter
> http://www.nabble.com/FeatureVector-and-atPoint%28%29-function-way-off.-Why---tp19966398p19966398.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
