[OpenLayers-Users] Using OL with Google baseLayer
Christopher Schmidt
crschmidt at metacarta.com
Thu Oct 16 06:42:34 EDT 2008
On Thu, Oct 16, 2008 at 12:16:54PM +0200, Jacolin Yves wrote:
> Hi list,
> I am switching my OL baselayers to the Google Maps's one. So I have to change
> my projection for all my data to "google mercator". All my datas were in
> lambert 2 etendue (french projection, epsg code: 27572).
> I succed to change it for all my shapefile using ogr2ogr or gdal with the
> following process:
> add this in the epsg file :
> [code]
> # Google Mercator
> <54004> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84
> +units=m +no_defs <>
> [/code]
This is not the Spherical Mercator projection. See
http://trac.openlayers.org/wiki/SphericalMercator : +nadgrids=@null is
missing.
> and use :
> [code]
> ogr2ogr -s_srs "EPSG:27572" -t_srs "EPSG:54004" destination.shp originale.shp
> [/code]
> BUT some of my datas are stored in a postgis database. I find two "epsg code"
> to add in the spatial_reference table:
> [sql]
> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, srtext, proj4text)
> values (900913 ,'EPSG',900913,'GEOGCS["WGS 84", DATUM["World Geodetic System
> 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563,AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
> NIT["degree",0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude",
> NORTH],AUTHORITY["EPSG","4326"]],
> PROJECTION["Mercator_1SP"],PARAMETER["semi_minor", 6378137.0],
> PARAMETER["latitude_of_origin",0.0], PARAMETER["central_meridian", 0.0],
> PARAMETER["scale_factor",1.0], PARAMETER["false_easting", 0.0],
> PARAMETER["false_northing", 0.0],UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
> NORTH],AUTHORITY["EPSG","900913"]] |','+proj=merc +a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m
> +nadgrids=@null +no_defs');
This one is right.
> INSERT INTO spatial_ref_sys (srid, auth_name, auth_srid, srtext, proj4text)
> VALUES (54004, 'spatialreference.org',
> 54004, 'PROJCS["World_Mercator",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Mercator_1SP"],PARAMETER["False_Easting",0],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",0],PARAMETER["Standard_Parallel_1",0],UNIT["Meter",1],AUTHORITY["EPSG","54004"]]', '+proj=merc
> +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
> [/sql]
Don't use this one.
> If I am using the 900913 projection, my datas are shift to the south from the
> right location.
No. If you're using 54004, your data is shifted too far north.
> I would like to know wich one is "the best" to use and why I have some
> difference! I am mixing all this in my mind :(
Regards,
Christopher Schmidt
MetaCarta
