[OpenLayers-Users] Customised Popup in Openlayers
Bijoy K. Anupam
bijoya at rediff.co.in
Fri Oct 17 02:34:16 EDT 2008
Hi Reena,
You will have to use normal JavaScript programming technique to accomplish
this. I assume you can insert anything into the popup from outside.
popup = new OpenLayers.Popup("chicken",
new OpenLayers.LonLat(5,40),
new OpenLayers.Size(200,200),
"YOUR CONTENT HERE",
true);
map.addPopup(popup);
You can pass on your javascript code using stringvariable = "<script>You
script here</script>"; This stringvariable goes in place of the argument
where you pass on HTML content to the popup.
If you want to program dependent dropdown boxes, you can do them using
JavaScript and AJAX or using only Javascript. One such example might help
you...
http://javascript.internet.com/forms/dynamic-drop-down-list-2.html
Thanks...
<BIJOY>
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of S.Reena
Sent: Friday, October 17, 2008 11:24 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] Customised Popup in Openlayers
I want to make a popup which has 3 drop down boxes...but the content of 2nd
option box depends on the contents of 1st option box...so we select 1st
option box ..den depending on this selection ..value comes in 2nd option box
....and so on .Is this possible?
Thanks in advance.
Cheers,
Reena.
View this message in context:
http://www.nabble.com/Customised-Popup-in-Openlayers-tp20027494p20027494.htm
l
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
