[OpenLayers-Users] Sort of Feature switcher
darrepac
pascal.darre at laposte.net
Sat Oct 18 04:08:44 EDT 2008
I was with FF too.... let me check again
thanks
Arnd Wippermann wrote:
> Sorry,
> I have not tested the page with IE. There was some console.log which only
> understand by FF. Now I have updated the page. I had to clear the IE cache
> to get the page correct loaded.
> The checkboxes should toggle between visibility of the features and the
> radiobuttons are for selecting a feature.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von darrepac
> Gesendet: Freitag, 17. Oktober 2008 23:19
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Sort of Feature switcher
> Hi Arnd,
> I am still playing with your example.
> What I do not understand perfectly is the role of the checkbox beside the
> feature name. It should be to toggle between visible and unvisible but it
> works only if first I select on the map the feature. If not unchecking
> many
> elements is doing nothing...like if there was a missing call to redraw
> feature.
> Same if I succeed to make one feature invisible, I can't get it visible
> again...
> I think there is one detail missing which doesn't make it work, but I like
> the concept
> thanks!
>> Hi Pascal,
>> Interesting problem. I have added some functionality to the last example.
>> Perhaps it helps.
>> I use a stylemap with addUniqueValueRules for the gml layer with a
>> rule for attribute visibility.
>> If the attribute visibility = "visible" the feature is visible.
>> To change the visibility, I change the attribute of the feature to
>> "hidden"
>> and redraw the feature.
>> I'm not sure, if it's the straight way, to change the visibility of
>> features.
>> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/select-featur
>> e-with
>> -function.html
>> Arnd Wippermann
>> [mailto:users-bounces at openlayers.org] Im Auftrag von darrepac
>> Gesendet: Donnerstag, 16. Oktober 2008 20:48
>> Betreff: [OpenLayers-Users] Sort of Feature switcher
>> Hello,
>> Thanks to Arnd, I have implemented a GML layer with some polygons on
>> top of an other layer (now WMS). Some polygons are one over an other
>> and sometimes, it is simply not possible to select one polygon as it
>> is behind some others.
>> For this reason and also to ease the User Experience, I would like to
>> have a sort of Feature Switcher:
>> Like the current layer switcher but instead of just viewing/uviewing
>> the different layer, I would like also to view/unview each feature of
>> my GML file.
>> So the user would be able to view only some specific polygon features.
>> Is there some way to do this?
>> thanks
>> View this message in context:
>> http://www.nabble.com/Sort-of-Feature-switcher-tp20016172p20016172.htm
>> l Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://www.nabble.com/Sort-of-Feature-switcher-tp20016172p20041231.html
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Sort-of-Feature-switcher-tp20016172p20044944.html
