[OpenLayers-Users] Update: Interesting Firebug exception report
Eric Lemoine
eric.c2c at gmail.com
Wed Oct 22 23:53:55 EDT 2008
This is an interesting one. Please keep the list informed on what
you'll find out. Thanks. Eric
2008/10/23, Greg Ederer <greg at ergonosis.com>:
> Hi Zac,
> Try removing OpenLayers.Event.stop(evt) at the end of your event handler
> method body. This seems to have fixed the problem (though, I have no idea
> why). I may go digging into the sources to figure it out. Please let me
> know if this works for you.
> Anyone have a clue?
> Cheers,
> Greg
> Zac Spitzer wrote:
>> I am also seeing exactly the same problem, first click error,
>> subsequent ones work
>> On Thu, Oct 23, 2008 at 11:26 AM, Greg Ederer <greg at ergonosis.com> wrote:
>>> Here's line 224 expanded:
>>> var factory=null;
>>> if(typeof GearsFactory!='undefined')
>>> factory=new GearsFactory();
>>> else
>>> try
>>> factory=new ActiveXObject('Gears.Factory');
>>> if(factory.getBuildInfo().indexOf('ie_mobile')!=-1)
>>> factory.privateSetGlobalObject(this);
>>> catch(e)
>>> if((typeof
>>> navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){
>>> factory=document.createElement("object");
>>> factory.style.display="none";
>>> factory.width=0;
>>> factory.height=0;
>>> factory.type="application/x-googlegears";
>>> document.documentElement.appendChild(factory);
>>> I'm not using Gears. Not sure what's causing this.
>>> Greg
>>> Greg Ederer wrote:
>>> The exception is traceable to OpenLayers.js (2.7) line 224:
>>> var factory=null;if(typeof GearsFactory!='undefined'){factory=new
>>> GearsFactory();}else{try{factory=new
>>> ActiveXObject('Gears.Factory');if(factory.getBuildInfo().indexOf('ie_mobile')!=-1){factory.privateSetGlobalObject(this);}}catch(e){if((typeof
>>> navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){factory=document.createElement("object");factory.style.display="none";factory.width=0;factory.height=0;factory.type="application/x-googlegears";document.documentElement.appendChild(factory);}}}
>>> Any ideas?
>>> Cheers,
>>> Greg
>>> Greg Ederer wrote:
>>> Huh. I fixed the URL, and I still get the exception on the first click.
>>> Greg Ederer wrote:
>>> I solved this. Bad wms URL.
>>> Cheers,
>>> Greg
>>> Greg Ederer wrote:
>>> Hi,
>>> I got the following exception:
>>> uncaught exception: [Exception... "Illegal operation on WrappedNative
>>> prototype object" nsresult: "0x8057000c
>>> (NS_ERROR_XPC_BAD_OP_ON_WN_PROTO)" location: "JS frame ::
>>> http://localhost:8080/EWX/scripts/OpenLayers-2.7/OpenLayers.js ::
>>> anonymous :: line 440" data: no]
>>> Line 224
>>> when executing the following code:
>>> OpenLayers.loadURL(this.map.parentFrame.wmsUrl, params, this,
>>> this.launchTimeSeries, this.launchTimeSeries);
>>> I only get the exception the first few times this method is called
>>> (within an OpenLayers.Control.Click click handler).
>>> this.launchTimeSeries does get called even when I get the exception.
>>> Any thoughts?
>>> Cheers,
>>> Greg
>>> | E R G O N O S I S
>>> | Greg Ederer
>>> | Lead Developer
>>> | 360.774.6848
>>> ________________________________
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>>> | E R G O N O S I S
>>> | Greg Ederer
>>> | Lead Developer
>>> | 360.774.6848
>>> Users mailing list
>>> | E R G O N O S I S
>>> | Greg Ederer
>>> | Lead Developer
>>> | 360.774.6848
>>> Users mailing list
> | E R G O N O S I S
> | Greg Ederer
> | Lead Developer
> | 360.774.6848
