[OpenLayers-Users] Vector feature attribute name
Alexandre Dube
adube at mapgears.com
Mon Oct 27 10:40:25 EDT 2008
Hi Bart,
Hey, that's a great idea. I'm using Mapserver ( shp data in uppercase
) and tinyows ( postgis data in lowercase ). I don't think changing
anything like that in tinyows might be possible, so I'll just try to add
aliases in Mapserver to attributes the sames as tinyows.
Thanks a lot,
Alexandre
bartvde at osgis.nl wrote:
> I assume you are using Mapserver?
> So why not create alias-es on your WFS?
> "gml_res_co_reg_alias" "RES_CO_REG"
> Best regards,
> Bart
>> Hi list,
>> I have a little problem with attribute names for vector features. In
>> my application, I have 2 data sources ( shapefiles and postGIS ) that
>> share the exact same kind of data. The only difference is the attribute
>> names, which are respectively in uppercase and lowercase ( ex. :
>> RES_CO_REG, res_co_reg )
>> My application must interact in both ways they are written ( or
>> preferably, ANY way they are written), so before using an attribute
>> name, I use this little function I've written :
>> OpenLayers.Feature.Vector.prototype.getAttributeName = function (szName) {
>> szName = szName.toUpperCase();
>> var szAttribute, key;
>> for ( key in this.attributes ) {
>> szAttribute = key.toUpperCase();
>> if (szAttribute == szName)
>> return key;
>> return false;
>> This works on feature objects. I didn't find a way to do it otherwise.
>> Like when using the addUniqueValueRules function, I have to do the
>> following :
>> oRegStyleMap.addUniqueValueRules("default", "RES_CO_REG", aRegColor);
>> oRegStyleMap.addUniqueValueRules("default", "res_co_reg", aRegColor);
>> To me, it seems like my solution is a big waste of time ( having to
>> loop into each attribute name every time )... Is there a better way to
>> do it ?
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
