[OpenLayers-Users] WFS Layers, Markers, Popups
Indika Tantrigoda
indika85 at gmail.com
Mon Oct 27 23:52:38 EDT 2008
Thanks for the reply.
It seems that when I click within the marker, I get different lon, lat
values.
Is it necessary to bind the markers to something ?
Also with the extractAttributes:true, how can I access the attributes of the
feature ?
Regards,
Indika
2008/10/27 Arnd Wippermann <arnd.wippermann at web.de>
> you can use a select control for the wfs layer.
> http://openlayers.org/dev/examples/select-feature-openpopup.html
> If you have load the wfs layer with extractAttributes: true, then your wfs
> data are saved in the attributes of the features.
> Arnd Wippermann
> *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *Im Auftrag von *Indika Tantrigoda
> *Gesendet:* Montag, 27. Oktober 2008 16:17
> *An:* OpenLayers users mailing list
> *Betreff:* [OpenLayers-Users] WFS Layers, Markers, Popups
> Hi,
> I have a wfs layer that displays points on my map, using markers.
> I would like to have a popup that displays data regarding the point which
> would get activated for a click event.
> I tried the following but, it seems to return all the data regarding the
> wfs layer, not the single point, irrespective of
> where I click on the map.
> wfs_cities.events.register('click', map, function (e) {
> document.getElementById('nodelist').innerHTML = "Loading...
> please wait...";
> var url = map.layers[2].getFullRequestString(
> REQUEST: "GetFeature",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: map.getExtent().toBBOX(),
> X: e.xy.x,
> Y: e.xy.y,
> INFO_FORMAT: 'text/html',
> QUERY_LAYERS: map.layers[2].params.LAYERS,
> FEATURE_COUNT: 50,
> WIDTH: map.size.w,
> HEIGHT: map.size.h
> "http://localhost:8080/geoserver/wfs"
> Any ideas how I can get around this ?
> Thanks in advance.
> Regards,
> Indika
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081028/8019dc12/attachment.html
