[OpenLayers-Users] WFS Layers, Markers, Popups
Arnd Wippermann
arnd.wippermann at web.de
Tue Oct 28 13:25:59 EDT 2008
Try this, to get all attributes for the feature:
function onFeatureSelect(feature) {
var Msg="";
for(var key in feature.attributes)
Msg += key + ":" + feature.attributes[key] + "\r\n";
alert(Msg);
but perhaps you mean city_name instead of citiy_name.
Arnd Wippermann
_____
Von: indika85 at gmail.com [mailto:indika85 at gmail.com]
Gesendet: Dienstag, 28. Oktober 2008 11:47
An: Eric Lemoine
Cc: Arnd Wippermann; users at openlayers.org
Betreff: Re: [OpenLayers-Users] WFS Layers, Markers, Popups
Thanks for the info. Got the featureselected event working.
I am having the issue of obtaining attributes of a feature.
This is how my code look like.
wfs_cities = new OpenLayers.Layer.WFS( "WFS Cities",
"http://localhost:8080/geoserver/wfs",
{typename: "topp:cities",
extractAttributes : true
{styleMap: new OpenLayers.StyleMap({
"default": cities_symbolizer//,
//"select" : cities_symbolizer_select
var selectControl = new OpenLayers.Control.SelectFeature(
wfs_cities,
{onSelect : onFeatureSelect});
alert(feature.attribute.citiy_name);
map.addControl(selectControl);
selectControl.activate();
The alert above does not show any output.
By following this method is it necessary to do the following also to extract
attribute information using GetFeature ?
wfs_cities.events.register('featureselected', map, function (e) {
document.getElementById('nodelist').innerHTML = "Loading";
var url = wfs_cities.getFullRequestString(
//SERVICE : 'WFS',
REQUEST: "GetFeature",
EXCEPTIONS: "application/vnd.ogc.se_xml",
//BBOX: map.getExtent().toBBOX(),
//X: e.xy.x,
//Y: e.xy.y,
INFO_FORMAT: 'text/html',
//QUERY_LAYERS: map.layers[2].params.LAYERS,
PROPERTYNAME: 'the_geom',
FEATURE_COUNT: 50
//FILTER: '<wfs:FeatureCollection
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc" service="WFS" version="1.1.0"
xmlns:gml="http://www.opengis.net/gml"><gml:featureMember><ogc:Filter><ogc:C
ontains><ogc:PropertyName>the_geom</ogc:PropertyName><gml:Point><gml:coordin
ates>'+lonlatxy+'</gml:coordinates></gml:Point></ogc:Contains></ogc:Filter><
/gml:featureMember></wfs:FeatureCollection>',
//WIDTH: map.size.w,
//HEIGHT: map.size.h
Thanks in advance
2008/10/28 Eric Lemoine <eric.c2c at gmail.com>
As Arnd said you should use vectors styled with externalgraphic and
the select feature control to be able to select your markers and
display a popup on feature selection. To be notified on feature
selection register a listener on the layer's featureselected event.
featureselected listeners receive an object with a feature property
referencing the selected feature. This is shown in the example Arnd
pointed you to. Eric
2008/10/28, Indika Tantrigoda <indika85 at gmail.com>:
> Thanks for the reply.
> It seems that when I click within the marker, I get different lon, lat
> values.
> Is it necessary to bind the markers to something ?
> Also with the extractAttributes:true, how can I access the attributes of
the
> feature ?
> Regards,
> Indika
> 2008/10/27 Arnd Wippermann <arnd.wippermann at web.de>
>> you can use a select control for the wfs layer.
>> http://openlayers.org/dev/examples/select-feature-openpopup.html
>> If you have load the wfs layer with extractAttributes: true, then your
wfs
>> data are saved in the attributes of the features.
>> Arnd Wippermann
>> *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> *Im Auftrag von *Indika Tantrigoda
>> *Gesendet:* Montag, 27. Oktober 2008 16:17
>> *An:* OpenLayers users mailing list
>> *Betreff:* [OpenLayers-Users] WFS Layers, Markers, Popups
>> Hi,
>> I have a wfs layer that displays points on my map, using markers.
>> I would like to have a popup that displays data regarding the point which
>> would get activated for a click event.
>> I tried the following but, it seems to return all the data regarding the
>> wfs layer, not the single point, irrespective of
>> where I click on the map.
>> wfs_cities.events.register('click', map, function (e) {
>> "Loading...
>> please wait...";
>> var url = map.layers[2].getFullRequestString(
>> X: e.xy.x,
>> Y: e.xy.y,
>> FEATURE_COUNT: 50,
>> WIDTH: map.size.w,
>> HEIGHT: map.size.h
>> Any ideas how I can get around this ?
>> Thanks in advance.
>> Regards,
>> Indika
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081028/2cf0cd55/attachment.html
