[OpenLayers-Users] OpenLayers.Request POST and IE 6/7 issues
Tim Schaub tschaub at opengeo.org
Wed Oct 29 15:06:35 EDT 2008
Ah, the key is at the bottom (content type):
OpenLayers.Request.POST({
     url: printURL,
     data: OpenLayers.Util.getParameterString(
         {width:size.w, height:size.h}
     headers: {
         "Content-Type": "application/x-www-form-urlencoded"
     callback: function(request) {
         alert(request.responseText);
Tim
Ian wrote:
>     $_REQUEST will contain form-encoded parameters (sent as data in a POST).
> Right, so using your getParameterString example:
> OpenLayers.Request.POST({url: printURL, data:
> OpenLayers.Util.getParameterString({width:size.w, height:size.h}),
> {alert(request.status);alert(request.responseText);}});
> should form encode width and height and it should be in the $_POST array
> correct? But it isn't. My PHP script is run, Firebug says
> 'width=500&height=500' is posted, but $_REQUEST, $_POST, and $_GET are
> all empty.
> I tested the $_POST array outside of OL with:
> <?php
>   if( $_POST["name"] || $_POST["age"] )
>      echo "Welcome ". $_POST['name']. "<br />";
>      echo "You are ". $_POST['age']. " years old.";
>      exit();
> <html>
> <body>
>   <form action="<?php $_PHP_SELF ?>" method="POST">
>   Name: <input type="text" name="name" />
>   Age: <input type="text" name="age" />
>   <input type="submit" />
>   </form>
> </body>
> and this worked correctly so my PHP installation is fine. I also tried
> using text/plain headers to no avail. OpenLayers.Request.POST data still
> is not showing up in PHP's $_REQUEST and $_POST arrays.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
