[OpenLayers-Users] Cluster and Scales map options
Eric Lemoine
eric.c2c at gmail.com
Thu Oct 30 13:27:33 EDT 2008
Yves, do you mean the cluster strategy doesn't work when a scales or
resolutions array is passed in the map options. If so it shouldn't be
difficult to modify the strategy cluster example and thereby provide a
good test case for this issue. Cheers, Eric
2008/10/29, Jacolin Yves <yjacolin at free.fr>:
> Hi,
> Working on polygon clustering I tested it on a special page in local, after
> replicating my changes to my dev of my application, cluster behaviour was
> not
> the same in my dev application.
> Indeed, some clustered point have to be removed and the real point have to
> be
> displayed, but this is not working. I find that the only difference between
> my test and my dev code was the definition of custom scale (I am using
> Tilecache). So I removed it and the cluster strategy works well.
> What do I have to change in my dev application in order to use Tilecache
> (and
> keep the scale custom definition) and cluster strategy?
> Regards,
> Y.
> Yves Jacolin
> http://softlibre.gloobe.org
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
