[OpenLayers-Users] User inputs in Popups
Indika Tantrigoda
indika85 at gmail.com
Fri Oct 31 09:21:35 EDT 2008
Hi Alexandre,
Thanks for the reply. I am referring to the html text box inside the popup.
Thats where I want to enter the data.
I also included a button in the popup to initiate the transaction. This
works fine when I hard code the attribute information.
I did try the method you suggested. Maybe because the html text box is not
directly in the web page(but rather in the popup) I didnt have much success.
However I will try this again. Maybe I missed something.
If there is any other way of achieving this (maybe with ajax) kindly let me
know.
Regards,
Indika
2008/10/31 Alexandre Dube <adube at mapgears.com>
> Hi Indika,
> >> The problem is I am unable to access the input data.
> Do you mean you can't access the html text box ? If you do, give it and
> id, access it with document.getElementById('yourId') and parse the text box
> value to the feature.attributes before saving. That will add the attribute
> to your INSERT/UPDATE request at the same time. I'm not sure if that's what
> you meant, though.
> >>Also everytime the wfs-insert takes place i get an alert with the
> transaction results details.
> Is there anyway not have the alert come up everytime.
> Search in your files for the "alert" string and just get rid of it.
> Hope this helps,
> Alexandre
> Indika Tantrigoda wrote:
>> Hello to all,
>> I have a wfs layer setup which allows me to add points.
>> I would like the user to enter the attribute information so that it too
>> can get
>> written to postgres.
>> I setup a popup with a text box which allows me to add the relevant
>> details.
>> Is there any way to get around this, or this is an alternative method I
>> could approach.
>> Thanks
>> Indika
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081031/ff666916/attachment.html
